A JD
SB
08-26-2002 12:58:08
what should i do to make a stock 1950 A JD into a competative puller?sb
A Man
08-29-2002 21:08:47
 Re: A JD in reply to SB, 08-26-2002 12:58:08
My A is a1951 model and it never run out of power just traction with 15.5 38 at the 10,000 and that is with 10 psi tire pressure and drawer bar at 20 inches. what next, any more ideas any would be nice
52 A Boy
08-28-2002 17:04:25
I have a 1952 JD A that is totally stock, with 14.9 38's on the rear and i cant get all the traction to the ground in the 6600 class. And bare with me on it im 5315 99% of the time.
52 A Boy
phil
08-26-2002 13:45:04
A nice feature of the late model A is the extra low first gear - you will never run out of torque, no need to add horses. Lift the drawbar up to about 20", lower the tire pressure to about 11 psi, and give it a try. It should weigh about 5300 lbs with driver aboard.
