Case DC bore question??
CASEPOWER
09-02-2002 12:03:08
Is it possible to bore a Case DC sleeve to 4-1/4 ??? Also are the 4" sleeves thicker on OD then a 3-7/8?? I know they go in the same hole size, but is there any thinner spots that would make boring a 4" better then a 3-7/8.
Kase
09-03-2002 04:07:38
 Re: Case DC bore question?? in reply to CASEPOWER, 09-02-2002 12:03:08
Hey i would love to talk case pulling with you. I pull a C in the 3500 - 4500. As far as the sleeve is concerned i heard 4 1/8 is the limit and that is questionable 4/16 will go easy. My eng is a loose 4 inch and i do run out of power at 4500 but winter is coming on and ive got lots of plans. Good luck
RoyG
09-02-2002 16:58:07
You will not have enough metal left if you try to bore stock sleeves to 4 1/4 - you can take 3 7/8 out to 4.
