How high of compression ratio can a JD 70 GAS go?
Jonathan
09-02-2002 14:35:51
How high can the compression get before the piston will it the valves on a JD 70 gas? I want to change the compression from 6.15:1 to 9.5:1 and is the rule of thumb 10% increase in power for every compression ratio raised. thanks for any info
lynn
09-02-2002 18:10:44
 Re: How high of compression ratio can a JD 70 GAS go? in reply to Jonathan, 09-02-2002 14:35:51
Jonathan..if you go 9.5 to 1 you will have .823 inches between the head and pistons if they were both flat..cam lift is only around .500 on a stock cam..you might get 10% for each point starting at 4 to 1 but as you go up in compression the % decreases..lynn
