Farmall m head
TL
09-05-2002 17:43:20
I have a farmall super m head with firecrater pistons in it and can't seem to find a head that will fit,what ever head I put on,when I roll the engine over it will pick the head up off the block over an eigth of an inch.Sure could use some advice. Thanks
frank
09-06-2002 16:45:53
 Re: farmall m head in reply to TL, 09-05-2002 17:43:20
just chuck up your pistons in a lathe and turn about 3/16" off the domes. a good lathe man ought to be to do this in about 20 minutes.heckuva alot cheaper than buying another head and having it redone.
Red'nOrange
09-05-2002 18:39:44
Sounds like you've got pistons for a dual fuel head. I've seen the firecrater piston for this type of head and they are built up significantly to fill part of the volume of the dual fuel head.
joe
09-07-2002 05:30:31
 Re: Re: farmall m head in reply to Red'nOrange, 09-05-2002 18:39:44
8060 head has the largest combustion camber at 200 cc
randy hall
09-06-2002 12:41:01
8060 head is the smallest combustion chamber for an original m head .
joe
09-06-2002 03:01:52
what is the part number of the head that you have
8060d should work it has the largest combustion chamber for a m
lbell
09-10-2002 06:57:22
 Re: Re: Re: farmall m head in reply to joe, 09-06-2002 03:01:52
do you have IH fire craters, or after market? We run IH high alt. fire craters and an 8060 head and have no trouble.
