BORE JD-G POWERBLOCK
2 cylinder
09-06-2002 15:48:20
WHAT IS THE VERY MAXIMUM BORE A JD-G POWERBLOCK CAN BE BORED?
Larry
09-09-2002 16:20:39
 Re: BORE JD-G POWERBLOCK in reply to 2 cylinder, 09-06-2002 15:48:20
I saw a power block for a JD G that was borded out to 7 1/2.
The puller
09-07-2002 16:37:25
I have a friend that has bored his G to crank out 75 horsepower on the dynometer w/o the air cleaner hose connected.
bigmotors
09-07-2002 05:17:54
I guess I do know a guy that went .045 over 6.750
But thats really thin. About 2 inchs of the sleeve in the back, I just cut it off when going this big. You'll see what I mean when you look at the sleeve.
I don't know why G Power Blocks read 7-1 on the block. That's why alot of people think they have 7 inch pistons. I had some old boy's tell me that Johnson Co. made a 7 inch bore block, can't say that I have ever seen one.
Good Luck!
bigmotors
09-06-2002 21:50:57
6.750 bore !
Alot of people bore them out to 6.625 or 6.6875 bore with no problems.
A puller
09-06-2002 22:39:17
 Re: Re: BORE JD-G POWERBLOCK in reply to bigmotors, 09-06-2002 21:50:57
isn't a G p.b. 7" bore?
Puller
09-07-2002 04:28:15
 Re: Re: Re: BORE JD-G POWERBLOCK in reply to A puller, 09-06-2002 22:39:17
No, a "G" Power- Block is 6.5". --
A puller
09-07-2002 07:59:17
 Re: Re: Re: Re: BORE JD-G POWERBLOCK in reply to --, 09-07-2002 04:28:15
then why does it have 7 casted in the top??
thanks
