Help on setup
Rooster in Tenn
09-08-2002 11:11:12
What is the weight of a stock Super M. I have water in the rear tires and weight 6470 with me on the tractor. Will a stock super pull in the 7500 class? Or do Ineed to pull in the 5500 class? What is the best setup for the super M? I pull in the 6500 class farm stock, I can pull around 210 feet, with water in the rear tires. I have no wheel weights on the rear or front. And front is never on the gound. Last night was my first pull. Any help would be appeciate.
Don
09-08-2002 19:21:10
 Re: Help on setup in reply to Rooster in Tenn, 09-08-2002 11:11:12
I pull a Super M, has hydraulics and belt pulley on it, no fluid in rear tires. I pull it in 5500, 6500, 7500, stalls in 8500. It pulls good. It has been dyno at 52hp. It has normal rear wheels with 13.6 tires on it. Good luck!
TL
09-08-2002 18:33:49
I would take that water out of the tires. put you a set of press steel wheels on the back. the more weight you can remove that you don't need the more weight you can put were you need it. what part of tennessee do you live and were do you normally pull?
Rooster in Tennessee
09-09-2002 17:46:37
 Re: Re: Help on setup in reply to TL, 09-08-2002 18:33:49
I live in middle tenn. I pull at eagleville the first time this weekend. I am new to the pulling. But I like it. All so have a 720 JD, have not got it run just right for pulling. It run for hay work. Thank's for info.
TL
09-09-2002 18:00:37
 Re: Re: Re: Help on setup in reply to Rooster in Tennessee, 09-09-2002 17:46:37
I pull in east tenn. I have a 400 farmall that i got it down to 4800 pounds with the TA.
Rooster in Tenn.
09-09-2002 18:42:44
 Re: Re: Re: Re: Help on setup in reply to TL, 09-09-2002 18:00:37
My friend got me into pulling, pulls a 400 gas. It pulls good. He got first place Sat. night. I hope my super M will in the 7500 class. I got a lot learn. Good luck and have fun.
