M Pistons
Need To Know
09-13-2002 05:07:59
Does anyone know the overall length of a Farmall M piston also the length from the top to the middle of the pin, I beleave it is called the compression height.
Thank you in advance
M Pistons
09-13-2002 07:33:08
 Re: M Pistons in reply to Need To Know, 09-13-2002 05:07:59
Compression height 3.124. Overall length is going to depend on which piston you have.
Major Thanks
09-13-2002 08:35:49
 Re: Re: M Pistons in reply to M Pistons, 09-13-2002 07:33:08
Could I also ask what the pin diameter is? 1.25 sound right.
M Pistons
09-13-2002 09:28:23
 Re: Re: Re: M Pistons in reply to Major Thanks, 09-13-2002 08:35:49
1.312 I believe is standard (or at least pin bushings are available for 1.312")
don geronimo
09-13-2002 11:23:56
 Re: Re: Re: Re: M Pistons in reply to M Pistons, 09-13-2002 09:28:23
1.312" is correct. you can also use 450 rods that use 1.00" pins.
