How can I get more HP from a 1066?
ihredpowerman
09-13-2002 07:16:03
I was wondering if anyone had some tricks or "little secrets" on how to squeeze a little more out of my 1066. I pull it at tractor pulls occasionally and I want to get a little more out of it with what I have to work with. If anyone has ANY tips, please get back to me.
Garry
09-16-2002 19:35:26
 Re: How can I get more HP from a 1066? in reply to ihredpowerman, 09-13-2002 07:16:03
These guys havent helped you much. Just turn up the damn fuel. put on a Switzer turbo and a straight pipe that should be about it. for a stock tractor. email me and i can tell u more specifics.
JDJIM
09-14-2002 20:41:22
I'm as John Deere Green as anybody , been pulling 6cyl diesels for 30 yrs , lets not knock the Red ones . I've seen the back of them more than they've seen me . I just like Deeres but it is a lot cheaper and easier to make a good puller out of a 1066 than any 4430-40 . They have so many more combinations to work with and they have the CROSS FLOW HEAD which we don't have . I know a lot of people that pull IH and with the parts available I could fix up a GOOD running IH for a fraction of what a Deere would cost , also the IH people share the information more than the JD's do . Just my $.02 worth .
A Man
09-14-2002 18:21:20
Paint it green
supermpuller
09-14-2002 18:59:39
 Re: Re: How can I get more HP from a 1066? in reply to A Man, 09-14-2002 18:21:20
The guy said he wanted more power not less.
A Man
09-14-2002 19:06:00
 Re: Re: Re: How can I get more HP from a 1066? in reply to supermpuller, 09-14-2002 18:59:39
you will get less with red
farm stock puller
09-13-2002 09:28:54
Sky is the limit it just comes down to how much you want to spend. The 1066's I pull against have bigger pump's (14mm), bigger lines and bigger injectors. They all have at least 466's in them some have gone to bigger cube's. The biggest thing that will help you is to get it ballenced right and get a good set of 20.8 x 38's or 42's radial tires. If your balenced right you should be able to get to the middle of the class. The last thing I can tell you is cheat. If they arn't checking the rpm's turn them up, if they arn't weighing add extra weight. You better belive that everyone else is too. It took me several year's to find out people arn't as honest as they seem, hey are there to beat you in any way possible. Don't bediscouraged though if you are having fun who care's what place you get.
ihredpowerman
09-13-2002 07:27:52
I am pulling this 1066 in farm stcok but of course evryone has the their extra boost. I want to know what little things I can do to get the max HP and still run stock
call HyperMax
09-13-2002 07:19:04
call them asap
and give
09-13-2002 18:15:39
 Re: Re: How can I get more HP from a 1066? in reply to call HyperMax, 09-13-2002 07:19:04
them your checkbook!!
