Tires Rims
Larry
05-26-2001 07:05:18
I pull with a John Deere 620 fresh engine am going to retire it, want to go with 14.9X38 but can't find 13 inch rims as recomended by Firestone can get either a 13 or 14 what would be best with this tire. Or should I just stay with 15.5X38 on a 14 inch rim. I pull in 6500 thru 8500and spin out with the present tires.
Slo
05-26-2001 07:11:23
 Re: Tires Rims in reply to Larry, 05-26-2001 07:05:18
I'd run the 14" rims on the 14.9's. They will help give you your pootprint at higher psi, which will help keep your drawbar up.
deere51A
06-17-2001 21:19:48
 Re: Re: Tires Rims in reply to Slo, 05-26-2001 07:11:23
hey
i pull a 1951 "A" John Deere and last year i had a pair of 15x5x38 armstrongs on it and i couldn't get it to pull in the 5500-6500 pound classes.i watched all the vidios my girlfriend taped and i found out that it was to low to the ground in the rear so i raised the drawbar from 18" to 20" it didn't help much.so i went a head and put a pair of 16x9x38 good years on the back and i still wasn't doing good.so i watched more vidios and after i spun out my holes were round not flat so they had 12 pounds of air in them so i took 2 pounds out of them and since then ive brought home about 5 1st place trophys. If u have any questions about how i raised the draw bar up or anything just e-mail me.
Glad to be of some help. Dustin
