Oliver hubs
Ohio H
09-17-2002 13:17:44
When adapting the oliver 77, 9 bolt hubs to a farmall H what is the most common adaption. Should i have the hubs machined to fit the IH axel/wheel key, or have the oliver key machined to fit the IH axel keyway. Just bought a really nice pair CHEAP!. Just dont know how to make them work. Thanks again to all you tractor genious's..... .H
va puller
09-21-2002 17:48:37
 Re: Oliver hubs in reply to Ohio H, 09-17-2002 13:17:44
ex h puller has the right idea. I took a 4.5"angle grinder and modified my h axles so the olliver 77 hubs fit like a glove. This took about 45 minutes per axle, not a big deal at all.The only alternative I could come up with was buying a set of weld-on 9 bolts. I did not want to weld on my axles so I gave the 77 hubs a try. I am very happy with the way it turned out.
ex h puller
09-17-2002 18:48:41
just take a grinder to the keyway on the axles and grind till the oliver key fits. I did mine that way and it worked fine. take your time and they will be fine. cheap too
Keith
09-17-2002 13:32:21
I have an IHC set I would sell you and you wont have to spend the money modifiying.
Ohio H
09-17-2002 16:01:43
 Re: Re: Oliver hubs in reply to Keith, 09-17-2002 13:32:21
Keith; thanks for the post but the IH hubs most likely wont fit. The H has a much smaller axel than the M, 460, etc. The only thing that fits that i know of is the oliver 77 hub at 2.5" if my memory serves me right. Anyway the hubs that i have are the right diameter, wrong key. but hey "thanks anyway"..... .H
Michael Earnest
09-17-2002 14:56:04
What type, how much, would they fit a 460\560?
