730 pumps inj.
Mike J
09-17-2002 21:59:45
I pulled my 730 diesel this year for the first time did okay in the 8500# class but am way under powered would like to put bigger inj. and pumps in but where do I get them and whats the cost. I had alot of fun pulling had tractor balanced as good as I could unless going up a weight class which is 10500#but that would mean I need more power yet so with more power my options open up alot more.
JDGnut
09-18-2002 20:18:01
 Re: 730 pumps inj. in reply to Mike J, 09-17-2002 21:59:45
Your 730 should have the 13mm pumps and the 6 hole .010 injectors.. the only tips that are bigger are the 830 6 hole .012 tips.. but they will not match the pistons in your 730.. Start with what you have.. have your tips and cracking pressures checked and set.. The 13mm pumps are the biggest they used in the 2 cylinders.. and they can deliver the fuel need for a stock tractor..
JDGnut
Mike J
09-19-2002 21:03:53
 Re: Re: 730 pumps inj. in reply to JDGnut, 09-18-2002 20:18:01
after having injectors checked how do I get more power or can't I ?
