Case tractor pullers
Jim
09-25-2002 23:38:37
Dad found a 630 Case, we want to get back into pulling and be competitive. We used to pull a VAI up into 4500 lb class very competitive. Can we compete with the 630. We think we can get it down to 4500. Any ideas? Jim
Jim M
09-26-2002 09:43:52
 Re: Case tractor pullers in reply to Jim, 09-25-2002 23:38:37
I had a 500B that I pulled. I pulled it in the 4500# 5000# and 5500# classes. Get a narrow front pedistal. If it has the round keyed axles get a pair of SC rear wheels which has 3 5/8 axles and the 630 should have 3 1/2 axles and with some tubing they will work so you can use 38" rubber,13.6 work well or if you go with tin wheels you should be able to get to 4000. I got rid of my 500B and got a 351 to fix up because of the year. The 630's I think were made 60-63.
