JD A for Div III or IV?
BK
09-29-2002 19:13:08
Looking into building an A, 1946 for pulling. What can you do with an A regarding stroke and bore? Anyone have parts they want to part with? THanx.
2 cylinder
09-30-2002 19:14:47
 Re: JD A for Div III or IV? in reply to BK, 09-29-2002 19:13:08
What kind of price tag are we talking about for this kind of setup? I have the powerblock with 6.125 bore and aluminum high compression pistons, with some head and porting work in a 47 JD-A that dyno's at 55hp, it does quite well in 4500-6000# classes but would like to power it up so I can run in the faster classes. I have been thinking about a stroker crank. Who would you recommend for this kind of work, and what is the price tag? Thanks.
bigmotors
09-30-2002 22:13:32
 Re: Re: JD A for Div III or IV? in reply to 2 cylinder, 09-30-2002 19:14:47
I've had good luck with Merfeld in Peosta, Iowa
For a big crank - $1000.00 to $1400.00
2 cylinder
10-01-2002 17:49:08
 Re: Re: Re: JD A for Div III or IV? in reply to bigmotors, 09-30-2002 22:13:32
How much will the rods cost to go along with the stroker crank? In other words what will the package deal cost, crank, rods and pistons. I have half the package with the powerblock, was just wondering what it will cost to build the JD-A the rest of the way. Thank in advance!
bigmotors
10-01-2002 21:52:03
 Re: Re: Re: Re: JD A for Div III or IV? in reply to 2 cylinder, 10-01-2002 17:49:08
Custom rods will run right around $225.00 to $250.00 each. Or you can weld up some rods using the top part of your A rod and the back half of a 404 or 466 cu. JD rod. You can use 329 cu. rods too. One has a 3 inch jor. the 329 is 2.750 jor.
You have to notch your cam, and knock the back out of the crank case for the rods to clear.
2 cylinder
09-30-2002 19:14:37
bigmotors
09-30-2002 02:02:48
What classes do you want to pull in?
The biggest A that I've seen was 6.750 X 10.150
4500 to 6500 lbs. in div. 3 and 4 will work good for your A. You can bore out the block you got for 5.750 or 5.875/ or sleeve to 6.250/ or find a power block, bore to 6.250 or sleeve to 6.500. A 9.250 to 9.500 crank works good, but takes alot of work to get in. 8.250 to 8.500 isn't to bad. 90 to 95 hp. is very possible with a good A. Let me know if I can help. I don't know everthing, but I can sound like I do.
Good Luck!
bigmotors
09-30-2002 02:02:30
Good Luck!
