Pulling cam for JD-A
2 cylinder
10-02-2002 06:56:09
What kind of horsepower gain are we looking at putting a pulling cam in a JD-A with a 6.125" bore in a powerblock with ported intake and head, and block and head milled. The tractor the way it is described above dyno's at 55hp. The majority of the pulls I go to don't have a RPM limit, and those that do allow 20% over on RPM's.
bigmotors
10-06-2002 03:46:10
 Re: pulling cam for JD-A in reply to 2 cylinder, 10-02-2002 06:56:09
If you don't want to spend the money for a custom ground cam, go with a 620 or 630 cam. It might help you,if you are allowed 20% rpm over.
A Man
10-02-2002 20:47:43
I use a stock cam and I can drag All the farmalls you can hook to the tracter backwards all day long stay stock and be sure your getting all the power to the track that is most imporant thing good luck
lynn
10-02-2002 17:25:48
2 cylinder..my best guess with a proper cam and degreed in would be about 2 or 3 horsepower..lynn
70 puller
10-02-2002 10:26:07
I messed with three different so called pulling cams (ie) low RPM high torque . I got best results from the stock cam .
