Hitch point Fwd-aft
Brian D
10-02-2002 07:00:35
I'm fairly new to tractor pulling. I have a tractor I've pulled a couple of times. It has plenty of power but even without any weight up front it will not lift the front end. It just spins out. I have the hitch set at the maximum height allowed by the rules. I keep moving the hitch farther back on the tractor but it still does not pickup the front at all or get very good traction. The drawbar is already back about 3 feet. I don't mind going back even farther if it might help. Maybe I just have not found the balance point or am I missing something. This tractor is keeps coming in a not so distant third or fourth please as it is so I think if I can figure out this problem I should be right there. I realize my tires must not be grabbing like they should but is it possible to go to far back with the hitch point? Thanks for your thoughts.
Jim M
10-02-2002 09:45:44
 Re: Hitch point Fwd-aft in reply to Brian D, 10-02-2002 07:00:35
What weight class are you pulling? What size tires do you have? What tread pattern are they? What pressure are you running? Sounds like you are on the right track.
A JD Puller
10-05-2002 19:28:40
 Re: Re: Hitch point Fwd-aft in reply to Jim M, 10-02-2002 09:45:44
what kind of tractor is it?????
Brian
10-02-2002 12:14:01
Antique, 8000lbs, 23 degree wide lug Firestone tires, seems to be best around 8 PSI. The tires are in fairly good shape with a lot of lug left. Maybe that is the problem.
Jim M
10-02-2002 15:28:33
 Re: Re: Re: Hitch point Fwd-aft in reply to Brian, 10-02-2002 12:14:01
What size?
