Free Advise
Farmall Fan
10-07-2002 11:53:00
Dear Farmall M thru 450 Pullers,
I am going to give you some free engine building advise to you since I am getting to old to pull anymore. If you are trying to increase your horsepower to a respectable Div. II plus range here is my 2 cents. First you pull your stock pistons out and throw them to the dogs to play with. Next you go to your local John Deere dealer and get 4 new pistons for a 4020 LP (must be LP cause the gas ones aren't flat top) tractor. These pistons should hit you for around $125. Then you contact a machine shape that can stroke cranks (personally I used the gentalman in the HOOK that advertises and they hit me for $500)to 6.125 inches (6 1/8"). Also you will need to have your block either bored or honed to 4.21" (the diameter of the 4020 LP pistons) Sorry I forgot to mention that the beauty of the 4020 LP piston is it has the same diameter pin as the M rod. This means you don't have to do any cutting and welding of your rods. Another added bonus is that 6.125" rods don't require any gringing in the block to allow for the added throw. Well I just wanted to share this info with you and use it as you will. I am sure there will be many of you trying to contest this as it seems there always is. Side not this set up will put you at around 342 cubic inch. If this number is wrong sorry I just did the math in my head real quick but I am sure you "engine builders" will correct it instead of focusing on the real issue at hand.
Retired
DAVID DAWSON
10-03-2003 15:13:08
 Re: Free Advise in reply to Farmall Fan, 10-07-2002 11:53:00
HI my name is david, i just like some advise about getting married and living together.....here goes....i live in England and my partner lives in the US, I'm going to the US to marry her, first of all I'd like to know if i can get married to her in the US on a 90 day waver visa.and secondly I'd like to know if i can bring her back her to live, and if i can what would she need to do to come here, visa ect,
and next we are both on benafits so would that make a differants, i read it will but i hope not, and if we cant live together here, would we be able to live in the US,,,,, thank you for your time,,hope to hear from you soon
Flyin Farmall
10-08-2002 15:55:20
What did you use for a cam,carb?did you use the stock M rods or the 450 rods with 1"pins?thanx.
Farmall Fan
10-08-2002 16:31:08
 Re: Re: Free Advise in reply to Flyin Farmall, 10-08-2002 15:55:20
I used a 450 gas cam a 400 Carb with an 806 ventur, and a 400 head that was redone. Rod were STOCK M rods.
burns
10-07-2002 18:19:07
John Deere parts in a Farmall!!!!! !!!!! !
The sky is falling!!!!! !!!!
Just funnin.
MAD DUC
10-08-2002 03:33:58
 Re: Re: Free Advise in reply to burns, 10-07-2002 18:19:07
Just shows ya what makes real power! John Deere. Just kiddin', nothing wrong with any color tractor.
EB
10-07-2002 12:49:02
Do you know what the compression height of the JD 4020 LP piston is????
Thanks
Farmall Fan
10-07-2002 15:58:18
 Re: Re: Free Advise in reply to EB, 10-07-2002 12:49:02
The compression Height is 2.625. This means you take 3.124 minus 2.625 equals .499. Then you multiply that by 2 to get .998 add that to 5.25 (Stock Stroke) and yes it equals 6.248. Yes I know this is more then what I said (6.125) because you have to allow some combution room for the flat top pistons and may need to mill a little off your head. To get your desired compression (personally I ran 10.5 to 1) I hope this helps.
Retired
puller
10-08-2002 11:36:03
 Re: Re: Re: Free Advise in reply to Farmall Fan, 10-07-2002 15:58:18
who was the man that did the crank for $500 and how long ago has that been? thanks
Farmall Fan
10-08-2002 11:59:05
 Re: Re: Re: Re: Free Advise in reply to puller, 10-08-2002 11:36:03
It was about 3 years ago and his name was Don ????? ??.
