? Where does it end?
Glenn
10-08-2002 17:31:45
Where does the out of bounds end on the tracks the rest of you pull at? does it end at the finish line , or do they strech on till infinity? Glenn
SEAMO
10-08-2002 20:41:16
 Re: ? Where does it end? in reply to Glenn, 10-08-2002 17:31:45
In Illinois they usually tell you at the drivers meeting before the pull starts. The track judge can extend at the beginning of the class.
Jack
10-08-2002 19:17:05
Well ours end about the 250 ft mark but I have seen a floating finish line quite a bit here latly.Jack(TN).
Jeff Oliver
10-11-2002 18:25:55
 Re: Re: ? Where does it end? in reply to Jack, 10-08-2002 19:17:05
Well Jack if you would take some of the power out of that old G of yours we wouldn't need that floating finish line..LOL!!!! Have to have one so they can say the sled stopped you on the track you know:)) Guess I am going to have to buy some more weights for my 88 and come up there and play in your classes some huh?:) Got the little guy ( B ) back running tonight. Might need you to ride by sometime and check the timing and all on it but it seems to be ok.
Jack
10-13-2002 10:13:18
 Re: Re: Re: ? Where does it end? in reply to Jeff Oliver, 10-11-2002 18:25:55
I will let you borrow some weights but they are the wrong shade of green.I will let you pull it sometime if you want to weight up.Later,Jack
