Displacement -vs- HP
PJ
10-09-2002 05:47:59
I'm not much of a motor guy, but I know that "there ain't no replacement for displacement." Whith that being said, when you increase your displacement by a certain percentage, does the HP gain have the same increase? For example if you increase your cu. in. by 25% does the HP go up 25%? I know that there are other factors to consider, but if you assume that you can get enough air/fuel etc. to the motor is the ratio 1:1?
Cubes and Power
10-11-2002 07:01:08
 Re: Displacement -vs- HP in reply to PJ, 10-09-2002 05:47:59
Because tractors run at such low RPMs the following may not apply, but it might shed some light on the matter. In an automotive engine the rate at which you can flow air in and out of the cylinders is generally what determines horsepower. In other words the cylinder heads, the intake and exhaust manifolds and the camshaft will generally determine your horsepower. For instance, if you take the same cylinder heads, intake and exhaust manifolds, and camshaft and install them on a 396 cubic inch big block chevy and then on a 502 big block chevy (which are, coincidentally, approximately 25% different in displacement), the 502 will make a little more power but not anywhere near 25% more. The 502 would make slightly more power because its larger cubes will produce a stronger vacuum and cause more flow with the same heads etc. and also because the bigger bores in the 502 will unshroud the valves and cause more flow.
The characteristic that is generally directly proportional to displacement is torque. In the example above the 502 would make approximately 25% more torque than the 396 and at a lower RPM. It is also worth noting that while the 502 with the same heads etc. will not make much more power than the 396 its peak horsepower will occur at a lower RPM.
The bottom line is that, all other factors being equal, torque is directly proportional to displacement, but horsepower is not necessarily. In many tractor applications where the engine is operating at such a low RPM that it is probably capable of nearly 100% volumetric efficiency (ability to flow air at a high enough rate to fill the cylinders 100%) throughout its entire operating range you may see directly proportional HP gains with displacement increases up to a point. There will come a point as the engine gets bigger and/or you run it at higher RPMs, however, where your horsepower will be limited by your cylinder heads, intake and exhaust manifolds, and camshaft.
Goldsburg
10-11-2002 07:59:58
 Re: Re: Displacement -vs- HP in reply to Cubes and Power, 10-11-2002 07:01:08
Cubes and Power -
I really enjoyed and appreciated your post. I just wanted to add that the cylinder heads on these old tractors are so poor that the typical "factory" maximum volumetric efficiencies are in the mid to upper 70's. When the induction system is improved (through head, cam, and manifold work), it still only reaches the 85 to 88% range. However, even this modest improvement in volumetric efficiecy, which is often accompanied by very substantial increases in displacement, add up to quite drastic improvements in power.
Regards,
Goldsburg
Turbine Dude
10-10-2002 18:01:13
Somebody please explain SEAMO really hit it o the head what is it with people "pull out the venturi and I will flow more are and make more HP!! Do these people not get the basic concept of a carb.....
Goldsburg
10-11-2002 07:51:53
 Re: Re: Displacement -vs- HP in reply to Turbine Dude, 10-10-2002 18:01:13
Turbine Dude -
Keep in mind that factory carburetors weren't sized for maximum power! They were sized for driveability, economy, responsiveness, and reliability. All of these factors will lead you to a carb that is smaller than ideal for maximum power. With that in mind, imagine what the ramifications are when the factory cubes are doubled!
The premise of this mod is that the engine vacuum signal is SO strong on modified antique tractor engines, even at wide open throttle, that the pressure drop required for proper fuel flow occurs through the entire carb. This eliminates the need for a "special component" called a venturi, because the entire carb has now become the "venturi"! Compare the diameter of your throttle plate to the diameter of the carb opening. This might remind you of the way that the venturi has one diameter for an opening and a smaller diameter in the middle...?
The main fuel circuit components will need correspodingly enlarged because the signal is not as strong as if the original venturi were in place, but it is certainly strong enough to meter fuel, if the correct components are modified.
In addition, dyno numbers do not lie! I have personally witnessed (on my own tractor) a 15% gain in power from this modification. This is quite substantial, especially considering that the carb is what was "legal" for that class. When there is no carb limit in a class (stock appearance doesn't matter), then this particular mod is not necessarily right for you or anyone else in that circumstance.
The fundamentals of physics are what makes carburetors work (thank you Bernoulli!). This mod was developed using those principals and is completely sound, viable, and reliable. Just because that you do not understand the way or the reason that some things are done doesn't mean that they are wrong....
Regards,
Goldsburg
SEAMO
10-11-2002 12:12:10
 Re: Re: Re: Displacement -vs- HP in reply to Goldsburg, 10-11-2002 07:51:53
GOLDSBURG,Max cubes high comp. high rpm.you more than likely don't need a venturi if you can keep your rpm up.The carbs I modify I try and enlarge them all the way through.Choke side, throttle plate, venturi area.The fuel side is the tough part when you can't run a fuel pump. I see so many go dry at the 200ft. mark.They start out smoking and end the pull missing. Stock Rpms the largest venturi you can get in a carb will work better on "MOST" carb than a straight hole ,maybe not on the peak horsepower but on the bottom end lugging when the engine pulls down throttle plate wide open and you are trying to get it out the gate.Stock rpms you can not afford to have a power loss when your tractor lugs down you are better off if it will hold the hp.on the dyno or maybe a increase. Just my 2 cents it has always worked for me.A good example is large cubes and low compression ratio.Most of the time when you have more cubes you will naturally have a compression increase. I did a carb for a man on a "A" Deere. My # 71 modified had very little increase in power. I pulled the plugs and the piston were 1.750 from top of block on a cyclone head.Men make sure you know your engine before you bolt on the modified carb.Have a good weekend. Lets have some fun. Earl
bud barenie
10-12-2002 20:49:11
 Re: Re: Re: Re: Displacement -vs- HP in reply to SEAMO, 10-11-2002 12:12:10
seamo !!!
carb info !!!!! key word lugging, running farm stock and can never get the tractor to lug !!!
not losing any rpm's in first gear pull !!! is the motor to strong or is the carburation wrong !
i feel like i'm driving a tractor with a straight stick to the carb !!! not quite that drastic,but she won't give any ground!!!! if the tractor is strong enough, do you come out of the hole slow!!!
Goldsburg
10-11-2002 15:44:46
SEAMO -
I appreciate your commentary, however the dyno work that I have done is on stock +XX% RPM tractors.
You have your theory about how carbs (and engines)should operate and I have mine: I personally do not want to have lug my engines down to get them to make power, for two reasons: Loss of ground speed and loss of airflow (power). If you have a governor on an engine, that governor will keep that throttle plate nearly closed until the load hits. The governor will then adjust the throttle plate position correspondingly to the engine load. Once the throttle plate reaches the "wide open" position, you have maxed out airflow and thus power. Any RPM reduction beyond that means that you are reducing airflow (and power). Your torque may increase as you drop in RPM's, but it will not increase as fast as the RPM's are dropping. Also, as torque rises you are now much more likely to spin out or loose traction in a loose spot.
The fact that you have reached and are now below max power levels means that you are no longer putting maximum power to the ground. If you are dragging your engine down well past the point that the throttle plate is at the "wide open" position (as determined by the governor) then I would suggest that you are in too high of a gear!
How many Open class pulls are won by the guy that has lugged his tractor waaaaay down...?
Regards,
Goldsburg
goldsburg@att.net
Seamo
10-11-2002 19:41:30
 Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Goldsburg, 10-11-2002 15:44:46
Goldsburg, Why don't you explain to me what kind of tractor is a "STOCK" +xx%.Where do you pull? This is not rocket science.Do you win every pull.If its not too far away I think I would like to come and watch. I am not too old to learn.Earl In Illinois
Goldsburg
10-12-2002 15:52:55
 Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Seamo, 10-11-2002 19:41:30
SEAMO -
I will try to slow down a little. Stock RPM +XX% is read as "Stock RPM+ (whatever)% (RPM) over". This refers to stock RPM +20% over, stock RPM +10% over, or stock RPM + 30% over, etc. Have you ever heard of the NATPA or USAP? That is one of the rules that both of them (and most other antique tractor pulling organizations) have. Get the picture?
No, I don't win every pull. But I do observe the other pullers (going down the track) when I am not pulling. I do not stand around an BS with other pullers and then have to run to my tractor when it is my turn to pull. I am sorry that I am what you might consider a fierce competitor by not BS'ing, but I like to win and enjoy doing so.
Why are you so offended that I do not agree with you? As I said in my prior post, you have your theories and I have mine, end of story.
As far as you being old, I do not know about that at all. What I CAN tell from your posts is that you are too stubborn to even consider other the side(s) to an issue...
Regards,
Goldsburg
goldsburg@att.net
SEAMO
10-09-2002 18:30:19
I think Doug is right on target here. The problem most people have is they don't know how to get the correct air fuel ratio to feed the cubic inches. I have seen some of these carbs that the carb experts have butchered up. They just make everything bigger they drill every hole bigger that they can run a drill bit through.I had a Ihc carb this year that didn't have any type of venturi.Some people dont even know what to do with a vacuum gauge. They get completely away from the basics.Earl in Illinois
Doug in OR
10-09-2002 16:19:38
Horsepower is only one factor to consider. Personally, I think torque is a better indication of how well a tractor will pull.
Horses!
10-10-2002 20:32:01
 Re: Re: Displacement -vs- HP in reply to Doug in OR, 10-09-2002 16:19:38
Actually Horsepower is the factor that determines how far you can move something in a given time. Torque is a static measurement of a force that tends to produce rotation. I can make thousands of lb. ft. of torque by pulling on a long bar with my hands. But I cannot do it very fast so very little work gets done or weight gets moved. When you combine a calculated torque number with the number of iterations in a given time, you can figure how much work is done or weight is moved. In a word, Horsepower.
Doug in OR
10-11-2002 14:45:09
 Re: Re: Re: Displacement -vs- HP in reply to Horses!, 10-10-2002 20:32:01
"Move something in a given time" ... I'll buy that, and it can be applicable for a car or truck. But with a tractor and the low RPMs, horsepower isn't nearly as useful as torque. What does you more good: 100 lbs/ft at 1500 RPM, or 200 lbs/ft at 750 RPM? By application of the horsepower formula, you'll find that both engines are developing the same horsepower. It's just that when you consider that when you use your tractor for pulling, the "time factor" isn't as important. I'll take the high torgue, low RPM engine for this purpose.
bud barenie
10-12-2002 21:04:43
 Re: Re: Re: Re: Displacement -vs- HP in reply to Doug in OR, 10-11-2002 14:45:09
i'm slowly reading down this discussion board, and we all agree on torque!!! so at 800rpm on an (m) how do you mantain the torque through the correct carb and desplacement!!! lets take a stock super (m) with 281ci (standard ovehaul) and how do i mate the rite carb !!! how do i set vacuum, timing, fuel load . !!! and does exhaust
temp mean anything !!!! on the track, when the motor is pulling hard, how do you know, for that motor , things are rite
SEAMO
10-11-2002 20:56:34
AMEN TO THAT. Earl
Horses!
10-12-2002 10:29:25
 Re: Re: Re: Re: Re: Displacement -vs- HP in reply to SEAMO, 10-11-2002 20:56:34
Given two engines of the same horepower, regardless of of torque or RPM, they will both pull the same load. The tire has no idea what RPM the engine is turning. If you have a 60 HP motor running 5000 RPM turning the rear tire at 100 RPM or a 60 HP motor turning 1200 RPM but still turning the rear tire at 100 RPM, the same work will get done or weight moved. It has nothing to do with lugging or torque. Torque is simply a calculated number in a formula, it will not move any weight.
G-MAN
10-14-2002 07:37:42
 Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Horses!, 10-12-2002 10:29:25
Torque is not simply a number calculated in a formula, it is the true measure of what work an engine can do, and is the twisting or turning force produced. Horsepower is the number simply figured in a formula. Horsepower - Torque x RPM/5252, regardless of what engine you're dealing with. And torque and horsepower will always be equal at 5252 rpm, whether you're dealing with a chainsaw engine or a V-12 Allison aircraft engine. Horsepower is nothing more than how fast you can get work done, which is why it alwatys increases with RPM, theoretically.
Emerald
10-17-2002 21:31:35
 Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to G-MAN, 10-14-2002 07:37:42
Mr. G-Man, I am sorry to say, you have your torque crossed with your horsepower! Torque by itself is motionless. Work is accomplished by horsepower. Horsepower is the product of torque plus motion. Your formula, Horsepower = Torque x RPM/5252, is what it is all about. My dictionary states: 1 horsepower = 550 foot-pounds per second. There it is again, torque AND motion.
I rather doubt that in all engines the torque and horsepower cross at 5252 rpm. Are you telling me that a 900 cubic inch "G" at say, 180 HP, and a Thundercat at 180 HP, both will have matching torque and horsepower at 5252 rpm? I think you would agree the "G" would be history at that speed and the big Cat would have fallen on it's face at such a slow speed.
The high-powered sled engine and the monster 2-cylinder engine both would do exactly the same amount of work at equal horsepowers. When the R's start dropping, the "G" comes on strong in the torque department, which, by the formula, keeps the horsepower from falling off rapidly. The Cat on the other hand, with it's "peaky" torque curve, will lose horsepower rapidly once the R's go away. Rest assured, at their power peaks, both engines are work output equals!
The original post was something about "no replacement for displacement". I agree that increasing displacement will most certainly increase power output. By itself, this simply increases the amount of air/fuel that can flow into the power/cylinder, be compressed and ignited. I believe much more power is gained by increasing compression ratio and rotating speed than by merely overboring the cylinders.
"Different strokes for different folks"
wake up
10-19-2002 14:52:59
 Re: Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Emerald, 10-17-2002 21:31:35
use the formula the torque and power curves do cross at 5250
Emerald
10-20-2002 10:10:52
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to wake up, 10-19-2002 14:52:59
What a misapplication of a formula! Of course both lines cross at 5252 when both inputs are the same. Duh! It is absolutely impractical to use this formula in that manner.
This formula is used to determine horsepower at a given speed and a given torque. Maximum horsepower is not synonymous with maximum torque.
And to reply to another post, torque as a measure or rotary force in the modern day formula and the foot-pounds term used in the original horsepower formula as a measure of linear force are both very accurate measures used in determining power output of any power unit, be it iron or be it horseflesh (or spaceshuttles). It's just that all power units are not capable of being measured in both manners.
Doug in OR
10-12-2002 10:57:51
Easy to say, if you can change transmission settings so easily. But unfortunately, we can't. Most of us don't have the have the ability to simply change to 1/2 the ratio - we are already stuck in the lower gear.
I'm assuming that we aren't talking about a Div 5 tractor or anything near it, since that didn't seem to be the case with the original post. I presume he is pulling Div 1 or Div 2.
torque
10-12-2002 13:52:50
 Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Doug in OR, 10-12-2002 10:57:51
In Div. 1,2,and even 3, it's torque to the ground that gets the pretty blue ribbon (and somtimes a trophy) don
Horses!
10-12-2002 15:14:18
 Re: Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to torque, 10-12-2002 13:52:50
Torque to the ground? Torque is a static force. It is a force that tends to produce rotation. But doesn't have to. Therefore it is convenient to use that term when describing a rotation force such as that producede by an engine. However it produces no movement. Such as holding 100 Lb ft of torque on a bolt that is already tight. Even in the early Nebraska tractor tests they measured in HP.
Belt HP. and Drawbar HP.
Pulling a sled is the classic example of HP measurement. If you had a spring scale instead of a chain hooked between the sled and the drawbar, then figured the weight pulled a certain distance and measured the time it took, you have HP!
The confusion, I think, comes from people incorrectly using the term "Torque" to describe the power that is coming from an engine.
I didn't mean to start an argument here. I was just hoping to share some information.
Doug in OR
10-12-2002 17:57:16
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Horses!, 10-12-2002 15:14:18
I quote you again.. "the time it took" ... I agree with your definition of horsepower - no qualms there. But in division I and II, time is not applicable. If it pull 150 feet and it takes me five minutes, and you pull 149 feet and it takes you one minute, I still win! Obviously, you developed more horsepower, but it was my torque that prevailed. (Assuming traction wasn't the limiting factor)
Time is an essential number in any horsepower formula. If time isn't applicable, then how do you compute horsepower?
Goldsburg
10-12-2002 16:00:30
Horses!
I agree with your statements, which are based in Physics and real life. However, I have found that trying to have a meaningful, thought provoking, and scientific conversation with the likes of people (like Earl "SEAMO") would be about as productive as trying to teach a dog to fart.
Thanks for trying though! I am sure that there are other people reading this will appreciate (and understand) your comments...
Regards,
Goldsburg
goldsburg@att.net
bud barenie
10-12-2002 21:17:27
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Goldsburg, 10-12-2002 16:00:30
intense discussion !!! horespower verses torque!!!
we all want horsepower to develope torgue !! torque doesn't move anything!!!! i sell fasteners for a living !!!! so after this discussion board i will slow my pulling down, not to release to much wheel spin, to keep torque inline , because their is no time limit!!! sled-verses distance-verses horespower-verses time! (i.e) traction-balance, i'm learing !!!! thank-you !!!!
Doug in OR
10-13-2002 12:34:16
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to bud barenie, 10-12-2002 21:17:27
Ummm.. torque doesn't move anything? You've got it backwards. You'll develop no horsepower without torque. Horsepower is nothing more than torque, used over a specific period of time. The torque is what does your work. The horsepower is what determines how fast you will do the work.
Unless you are given extra points for moving a sled faster, and that would be hard to determine, since the sled weight varies as distance increases, you are better off to know you have enough torque to do the job.
Doug in OR
10-13-2002 13:44:30
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Displacement -vs- HP in reply to Doug in OR, 10-13-2002 12:34:16
I still agree with you, but you mis-apply the uses here. Thrust is used to measure things like the space shuttle, jet engines, and other such things. Thrust can be more quickly converted to horsepower, as opposed to torque. The point that keeps getting missed here is... we are talking tractor pulling, not stock car racing or jet aircraft performance. You need torque to turn a tractor tire, and all other explainations of horsepower, torque, or whatever, won't change that. You need "time" to measure how much horsepower you are producing. Yes, when properly geared, you can use horsepower as a factor in how well your tractor will pull. And this would be even more true if I had a continuously variable transmission. But this isn't how it is done in a real life division I tractor pull. The tractor that lugs down and keeps on pulling (and this lugdown point is usually not where the maximum horsepower is developed), is the tractor that usually does well in a pulling contest.
If it had lots of $$$, and could engineer my own engine, I'd make horsepower one big consideration. But in real life division I and II pulling, you must stick pretty much with what the manufacturer puts in that tractor. As one of the original posters said, once you've slowed the engine to where the volumetric efficiency is high, you'll be getting all you can from that engine. This will not be at the point where you are making maximum horsepower.
Horses! last post.
10-13-2002 13:00:29
Torque will not move anything. That is correct. Horsepower can certainly be developed without torque. A Horse produces no torque. Yet it can pull a plow or sled and get work done. That is drawbar HP for a tractor. TORQUE is not a factor!!!!! It is a misused term that describes a force that tends to produce rotation. But rotation is not required. The space shuttle produces no torque yet puts out hundreds of thousands of HP.
Why do people use the term then? It primarily comes from using a dyno to measure the HP of an engine. Such as the original Prony Brake. It converted the rotation of the engine into a static force using a brake on a pulley and measured the pressure produced at a given distance from the centerline of the rotation. This converts the rotational force into a linear static force so it can be used in the HP formula.
So once the "Torque" or rotational force was eliminated from the equation by converting it into linear force using the brake apparatus, HP could then be determined. To eliminate that step in the calculation, a common simplified formula was derived resulting in (Torque X RPM) / 5252.
If the true physics calculations are used which rates it all in Kilowatts and or Newton Metres, we would never have heard of torque.
Andy
10-09-2002 06:47:52
I think there are too many factors to come up with a standard ratio: rpm's compression ratio, the flow of heads and carb, the person that built it, etc
