Governor help
andy
10-09-2002 17:36:02
trying to get better responce and quicker wide open throttle out of the gov on a WD AC. I have tryed lighter weights lighter springs, lighter weights heavy springs , reshaped the contact pads on the weights, and all kinds of linkage adjustments. anyone out there had any luck in this area?
bigmotors
10-12-2002 05:07:49
 Re: governor help in reply to andy, 10-09-2002 17:36:02
Kenny!!
I see you found my E-Mail!
Andy - Like Kenny said - if your having that much problems with it, replace it with AC 175 parts.
And like the rest said - A WC/WD governor work sometimes to good.
Ken Foland
10-11-2002 19:55:06
Andy the best thing you can do is get a 175 overhaul book. Get new 175 weights,pins,spring, spindle,and fork. Make sure your gear is excellent and then set it up according to the 175 book. This stuff is a little pricey from Agco but it is the only way to fly.
puller
10-11-2002 14:24:05
looks like the people at Denny's are the only ones that know anything about governors, since nobody else has any ideas or tips for Andy.
andy
10-10-2002 02:33:44
what do they do to those farmall gov to make them so responcive they claim wide open throttle at all rpm's anybody been in one to see what was done, or is that just another fake claim?
SEAMO
10-11-2002 19:18:34
 Re: Re: governor help in reply to andy, 10-10-2002 02:33:44
ANDY I told you to get hold of Butch in Ohio. He is always on the Allis or Case forum. Did we try to help you or not????? Earl
Seamo
10-09-2002 17:57:23
ANDY, You must have overlooked something because they are a very good governor stock. There is a complete check list to making the gov respond. You need to find a old retired Allis mechanic that made his living working on them.Where do you live.Get on the Allis forum and get Butch from Ohio to walk you through it. Earl in Illinois
Mike B (SD)
10-11-2002 18:08:11
 Re: Re: governor help in reply to Seamo, 10-09-2002 17:57:23
I agree with SEAMO. Allis governor's are lightning fast without needing help. I usually detune mine a bit. Does the starter turn the engine over normally, if not I suspect something internal.
