4430 turbo bolted on to 4020 block?
John
10-12-2002 18:06:13
Hey guys:
Instead of hunting an M&W kit, can I get a turbo and manifold off of a 4430 and bolt it up to my 4020, i think it will make a noticable difference, but can it be done without junking a good hood?
Thanks,
JOhn
J in Mn
10-13-2002 09:00:41
 Re: 4430 turbo bolted on to 4020 block? in reply to John, 10-12-2002 18:06:13
Too much pain, no gain! The turbo will be a measly 1" too tall for the hood. Beside that, if you have early, firewall mounted dual SCVs, the JD exhaust manifold interferes there also. The M&W manifold is the way to go, even if you are transplanting a complete 404 Turbo engine into a 4010/4020.
long
09-09-2003 19:10:43
 Re: Re: 4430 turbo bolted on to 4020 block? in reply to J in Mn, 10-13-2002 09:00:41
use a 4320 exhaust & intake manifolds, and turbo. The farmer next to me did it to his early style 4020, and was no problem with the hyd. remotes, and worked out great. He also taped into the vien,(where the AC.compressor would be on a 4430) for the return line, and came off the oil cooler housing for the pressure side. It runs really good, looks professional, and looks stock. Also he did not do anything to his hood.
