F-20 won't fire
dave
06-02-2001 10:19:42
my pulling f-20 won't fire. it is a hand crank. we have spark on all four. and we are confident on the timing. it acks like it's not getting gas, when we pull the choke gas pours out the bottom of the carb. after a few cranks it may pop but thats it.gas only commes out the carb when cranking though.
dave
06-02-2001 14:11:10
 Re: f-20 won't fire in reply to dave, 06-02-2001 10:19:42
adding to the problem. could I have blown the head gasket. we have increased the compression and it did back fire once . I notice some moisture that does not look like gas on the plug.
Rick
06-04-2001 21:06:40
 Re: Re: f-20 won't fire in reply to dave , 06-02-2001 14:11:10
How do you know the mag and motor is in time, and how do you know you are getting spark.
dave
06-05-2001 11:17:00
 Re: Re: Re: f-20 won't fire in reply to Rick, 06-04-2001 21:06:40
found the problem. when pulling apart to fix the bad gasket. motor is in time with plugs out checking spark at tdc will fine time when back together. found the shop had stuffed a towel in the manifold when they cleaned it. was sucked all the way to the valve and was poking out the valve face . plugged two intake ports completely. great huh.
