NEW SUPER MTA PULLER-HELP
Ed Cunningham
10-13-2002 19:55:10
NEW PULLER, I'M GOING TO INSTALL A 450 LP HEAD ON MY SUPER M 264 BLOCK. WOULD LIKE TO KNOW WHAT MY COMPRESSION SHOULD RUN ON STOCK BLOCK AND HOW MUCH CAN I BORE THE BLOCK AND HOW BIG OF A STROKER CRANK CAN I RUN WITH A 450 LP HEAD? NOT TO HAVE TOO MUCH COMPRESSION. I HAVE BEEN TOLD I CANNOT RUN DOME PISTONS, IS THIS TRUE? I'M GOING TO DO THE BASIC ELECTRONIC IGNITION UPGRADE. WHAT SPARK PLUGS SHOULD I RUN AND FUEL MIXTURE? WHAT CAN I DO TO THE GOVERNOR FOR MORE RPMs, CAN I RUN A STOCK CARB?
DeeCill to Dust
10-14-2002 16:26:13
 Re: NEW SUPER MTA PULLER-HELP in reply to Ed Cunningham, 10-13-2002 19:55:10
WHOOO: Too many questions Too little room
FIRST question; What state are you from?
SECOND What level of pulling are you going for?
THIRD What weight classes do you pull?
FORTH What are the rules for the club you pull? FITH HOW MUCH MONEY DO WANT TO INVEST?
Ed Cunningham
10-17-2002 17:15:17
 Re: Re: NEW SUPER MTA PULLER-HELP in reply to DeeCill to Dust, 10-14-2002 16:26:13
IM FROM M.O. IM GOING TO BE PULLING AROUND HOME.ONLY RULES ARE WEIGHT CLASS,I NEED TO WAY BECAUSE I PUTT STAMP WHEEL ON,AND REMOVED PTO.IM THINKING 4500 5000 5500 6000 CLASS.MONEY ???
