MM carb
A puller
10-17-2002 19:27:36
I'm building a 600+ cube MM U and I want to know what manifold, and head, and carb to use. What tractors to take the parts from, and parts numbers. I am thinking of going with the m5 jugs, any good way to sleeve one and be able to keep water in?
thanks alot, A puller
Jed
10-18-2002 18:25:36
 Re: MM carb in reply to A puller, 10-17-2002 19:27:36
Dont waste your time building a little motor. Youll have to get over 700 to even be competitive.
David
10-18-2002 05:50:39
Email me and I'll answer your questions, most people on here will just ridicule you.
Slo
10-18-2002 04:58:53
Call Matt at Motec - 765 963 6628. He should be able to help you, and if he can't, he can at least point you in the right direction. He does lots of pulling carbs. He has done a lot for me, and I'm very happy with the quality and price of his work.
ted
10-18-2002 07:05:59
 Re: Re: MM carb in reply to Slo, 10-18-2002 04:58:53
What is Motec, just a carb shop, or is it a engine shop? Where is it at?
Slo
10-18-2002 08:02:41
 Re: Re: Re: MM carb in reply to ted, 10-18-2002 07:05:59
Motec specializes in carbs, but has done a bunch of engine work in the past. He doesn't do as much engine work as in the past, as the carb business keeps him extremely busy. Located at Tipton IN.
Augie
10-17-2002 19:59:37
Ya ain't gonna get a straight answer at this place.
J in Mn
10-20-2002 06:54:33
 Re: Re: MM carb in reply to Augie, 10-17-2002 19:59:37
Don't "Go Here", or your computer will be under siege!
