Case Pullers
Shultzy
10-20-2002 13:11:25
Why does there seem to ba a lack of Case 70 series tracors in most pulling circuits? When you can start out at 504 cubes with the 1370 and bigger blocks, I'd think that would be a big advantage there from the get go. I know that you might not be able to interchange blocks with some pulling organizations, but still - it seems like there should be some potential.
I've hear that the heads don't flow too well. Is that the major part of the problem, or has there just not really been anyone out there that has been able to consistantly make one a good runner like Hypermax for IH, etc.
Thanks for any input. Just curious
superfarm case
10-21-2002 07:46:38
 Re: Case Pullers in reply to Shultzy, 10-20-2002 13:11:25
There is quite a bit of case tractors pulling in hot farm and superfarm . you can really crank the hp on them 451 and 504 engines . I know a few that are running that have 620 cid and they have the regular heads witch are ported and polished and big valves and some of them are getting around 325 cfm which is not to bad for any manufacturer's head . But there are some people putting custom alluminum heads on them tractors also and they can put out over 400 cfm. Riverside Engines in Tiffin , Ohio work on case ,they are mostly JD but they will work on a case from time to time.
case 1175
10-21-2002 10:12:06
 Re: Re: Case Pullers in reply to superfarm case, 10-21-2002 07:46:38
What is done to get 620 cubic inches out of my 451? I mean what pistons are used 5020 pistons or somthing else. Will I have to stroke the crank? I was just wondering I'm going to rebuild my 1175 this winter to a 504 and was wondering how muck more money I would be to go bigger?
730
10-22-2002 19:04:52
 Re: Re: Re: Case Pullers in reply to case 1175, 10-21-2002 10:12:06
I'm building a 1175 myself for farm stock going .060 over heads port polished 3 angle valves bigger lines and injectors also pump work and cam ground set for 3000rpm's thats are limit here! for about $8,000 I know a guy who builds 504 up to 629 using darton steel sleeves, mack pistons and stock rods with a 51/2 stroke crank,and custom built heads talks 800hp Our stocker should be around 225hp, but only $4000 spent
joecool
10-22-2002 19:11:15
 Re: Re: Re: Re: Case Pullers in reply to 730, 10-22-2002 19:04:52
do you have a turbo or not? water injected or not?
I sent a reply to this question on the case forum of ytmag. We are planning on building up a 451 with 504 parts.
730
10-22-2002 19:04:35
Chuck
10-20-2002 17:03:01
The heads flow very well 1370's are to heavy not any aftermarket hot rod part's made for a case but if you have the tallent to make your own part's you can take a 970 or 1070 504 ci. it and make it a very compitive in a hot farm single turbo class with the 8 speed tran's. and not have to sell the farm
