Spin out Special
Rick
06-04-2001 20:58:40
I have a set of Goodyear Spin out specials on my super 88, getting tired of going to pulls just to spin out on a good pull. what is a good pulling tire to use.
G Taylor
06-06-2001 13:10:06
 Re: Spin out Special in reply to Rick, 06-04-2001 20:58:40
What is the wheel speed & do you ever get the front tires in the air?
Rick
06-06-2001 21:39:36
 Re: Re: Spin out Special in reply to G Taylor , 06-06-2001 13:10:06
Not sure of ground speed, but I do know front up I spin out, add weight to hold the front down still spinout.
G Taylor
06-07-2001 11:21:29
 Re: Re: Re: Spin out Special in reply to Rick, 06-06-2001 21:39:36
Just checking to ensure 99 to 100% of the tractor weight was on the rear wheels when you spin out. Have seen Good Year 23 degree bias ply pull as good as any. Too low tire presure is a commom problem. If the tire bars bend instead of standing straight & digging in = loss of traction. Lets the drawbar drop too, reduces weight on drawbar, increase weight/drag on the sled plus more dirt ahead of the pan to push.
Joe
06-05-2001 18:43:53
What are you complaining about? At least yours runs long enough to spin out! I think I am going to shoot my mechanic. My tractor hasn't run right since I started letting me work on it. I may be able to help on the tire thing. Send me an e-mail.
Greg H.
06-05-2001 13:29:26
Firestone field and road 14.9 or 15.5x38 would work nice on your ollie. If you could find an old set of armstrongs that are weathered and harder than chinese arithmatic, with a 23deg bar, they'd work too.
Bill
06-04-2001 21:02:14
Add some weight to your 88 and put it up there with the really 3 plow tractors and then see what happens
Rick
06-04-2001 21:12:57
 Re: Re: Spin out Special in reply to Bill, 06-04-2001 21:02:14
Pulling 5500 to 6500 class, have M&W rear wheel weights on now 365lbs each. Tractor will pull 67 horse on the dyno, 6400 on the scale.
Rick
06-04-2001 21:21:33
 Re: Re: Re: Spin out Special in reply to Rick, 06-04-2001 21:12:57
By the way, did I tell you when I pull in the 6500 to 7500 class with the real 5 bottom tractors, I still spin out.
Bill
06-04-2001 21:51:59
 Re: Re: Re: Re: Spin out Special in reply to Rick, 06-04-2001 21:21:33
Maybe you should try a pair of 30.5x32's if they dont work maybe you could run duels. If your still spinning out in road gear, maybe you could get some 20.8x46's and run triples. If that dont work i guess maybe you should just park it back in the fence row with with the old stieger that wount pull the 18 bottom plow, and just keep farming with it.
Rick
06-04-2001 22:05:53
 Re: Re: Re: Re: Re: Spin out Special in reply to Bill, 06-04-2001 21:51:59
I would say you are one of those guys I out pulled back when, and you are still mad. I`am sorry but that is just pulling, Better luck next time Mr. Bill.
Bill
06-04-2001 22:10:06
 Re: Re: Re: Re: Re: Re: Spin out Special in reply to Rick, 06-04-2001 22:05:53
Yeah i think you did out pull me, i was the guy that had the 8N ford with the turf tires, you remember me i was pulling in the 10500lb no blower class, i pulled 299feet i think you went 301feet. But my 66 horse ford just wont keep up with those 67 pony you have, guess im going to add a little octane boster for next time
Rick
06-05-2001 09:54:44
 Re: Re: Re: Re: Re: Re: Re: Spin out Special in reply to Bill, 06-04-2001 22:10:06
Ok you win, can we talk about tires now.
pete
06-05-2001 06:05:38
now you boys sound like burns...i've heard of really large G's getting ALMOST 67 horsepower!?!?!
