IH 660 vs Cockshutt 570 super
baystatebinder
10-21-2002 05:33:13
Which tractor would make a better pulling tractor.
Gary
10-23-2002 18:39:02
 Re: IH 660 vs Cockshutt 570 super in reply to baystatebinder, 10-21-2002 05:33:13
It all depends on what division/classes you intend to pull in. I have a 570 that can pull the 5000 and up classes in division 4&5. I also like to wind up the rpms a bit and run field/farm stock. The tractor balances well and has a good trans. and r-end. It takes some work to get many cubes but you can increase them significantly.
Baystatebinder
10-24-2002 08:20:58
 Re: Re: IH 660 vs Cockshutt 570 super in reply to Gary, 10-23-2002 18:39:02
Has anyone done a check on the amount of hp you can make. How many rpm's can you run them at safely?
Cookie
10-24-2002 17:09:02
 Re: Re: Re: IH 660 vs Cockshutt 570 super in reply to Baystatebinder, 10-24-2002 08:20:58
With the cockshutt you can run around 3500 to 4000 rpms pretty safely with the 7 main crank not to sure with the 660 but still around 3000 I had a 570 i used to pull in the 6000 poudud class with 16.9 * 38 and did pretty good but always wanted to add a turbo.
Ken Williams
10-23-2002 08:24:26
Either tractor, would make a good puller. In our club, the IH 660's usually pull in the heavier weight classes,(10,500lbs through 13,500lbs). They are very competitive there. We have a Cockshutt 570 that pulls about 10,000lbs. He is very competitive around that weight.
Happy Tractoring, Ken
m puller
10-21-2002 07:36:14
Cockshutt 570 cause it is better balanced .
