Cam Grinding?
Brad
10-21-2002 18:34:41
I would like to hear from some of you that have had your cam's ground, and who you think does a good job. I have heard a lot of comments like I had to put a stock cam back in. Dont need that!
Flyin Farmall
10-22-2002 09:32:58
 Re: Cam Grinding? in reply to Brad, 10-21-2002 18:34:41
I had Isky grind one for me and it was a piece of garbage!!2of the lobes were ground 180 degrees off.
Ron
10-22-2002 06:46:08
I am just wondering----- does anyone consider what a good re-work of the valves ( ofcourse the ports, too )....will do for air flow in and out...??? I always Back-cut the valves in several angles, then polish....It increases the effective valve lift, and effective airflow duration... I cut right out to the seat contact area, in increasing angles, to smooth air-flow... Makes a big difference..!! Ofcourse, I have my own valve/seat grinder... I find it more accurate than the work done at NAPA.....
Ron
10-22-2002 06:45:14
Wide Front SM Puller
10-22-2002 04:05:07
Bullett racing Cams in Memphis, Sonny worked for Lunanti Cams for years and now does his own. He does a great job and is a great person.
Great cam, great service, quick turnaround, you can't beat it.
Let me know if you need his address and number.
flying farmall
10-22-2002 03:55:29
Denny's did a great job for me.
LW
10-21-2002 20:11:12
Berry's Cam Service lester prarie,MN 320-395-2377 they do fine work and can do your lifters, I have checked behind them and you get what you ask for.
DMoos
10-22-2002 12:08:26
 Re: Re: Cam Grinding? in reply to LW, 10-21-2002 20:11:12
How much does Barry's charge? I have a John Deere A.
Thanks
big iron
10-22-2002 12:49:15
 Re: Re: Re: Cam Grinding? in reply to DMoos, 10-22-2002 12:08:26
Berry cams just reground a cam for my 70 JD gas. I secified stock R.P.M. He reground the cam and lifters for $144.00 shipping included. I am happy with the work and 1 week turn around. While the engine was apart I ported the head and ground the valves, took 1/4" off the deck surface and installed ,045 over gas pistons. I have not had much time to mess with the thing on the dyno. I just more or less base lined it. I had about 60hp at rated R.P.M. It seems to me the cam build a little more power at high idle than the stock cam. I'm going to give it more fuel and mess with timing when I get a chance.
Seamo
10-21-2002 19:41:15
I need your E-mail if you want to talk cams. Earl
john sullivan
10-31-2002 17:22:46
 Re: Re: Cam Grinding? in reply to Seamo, 10-21-2002 19:41:15
i agree with widefront sm puller sonny daniels has done three cams for my m and super m pullers he is hernado,ms and or around memphis,tn bullet cams does great work give him a try
