HEY BIGMOTORS
2 cylinder
10-22-2002 20:02:27
How far can you stroke the crank in a 47 JD-A with a powerblock without having to displace the cam or other internal components? I'm not worried about a little grinding, notching and opening the back of the crank case.
Thanks.
bigmotors
10-28-2002 22:54:26
 Re: HEY BIGMOTORS in reply to 2 cylinder, 10-22-2002 20:02:27
10-4
The 1947 to 49 frame needs more support toward the front of the block when you go big.
The motor tends to rock. It can be as simple as some of the other power blocks, two bolts torward the front on the bottom, and two on the sides for support.
Again, this is what I have found, it might work fine for you.
Good Luck!
bigmotors
10-23-2002 02:24:27
Right around 9.500 to 9.625 crank.
Notch your cam around .600 thick for 2.750 jour.
I know of 10 inchs A's with out moving the cam, but thats to harry for me!
I had a cam that was .450 thick that broke when the tractor ran backwards.
I would strap the block, if your going that big in 1947 frame.
Good Luck!
2 cylinder
10-23-2002 14:41:56
 Re: Re: HEY BIGMOTORS in reply to bigmotors, 10-23-2002 02:24:27
What do you mean by strap the block and where would you do it. You probably want to do this for anded support I assume.
JDGnut
10-23-2002 08:38:29
Strap the block?? where are you adding support?
Just curious.
JDGnut
