M piston height
bob
10-25-2002 12:43:38
my m has a dome on the piston of .187 or 3/16 of a inch.it had a #8060 head and 100 psi compression. I have already put a 450 gas head on it increased my compression to 125 psi. Is there a better piston I here everyone on this board say the have 200 psi or is that because the have stroked there engines
Wide Front SM Puller
10-25-2002 15:19:41
 Re: m piston height in reply to bob, 10-25-2002 12:43:38
I am running the M&W "add power" dome pistons with a 450LP head and get 245psi. I have an extra 450 LP head if interested, it ain't cheap, but it helps.
JAS
10-30-2002 16:37:25
 Re: Re: m piston height in reply to Wide Front SM Puller, 10-25-2002 15:19:41
I have just bought a Farmall "m".How much are you asking for the lp head?
WILDMAN
10-28-2002 05:20:34
CALL GARY AT 704-732-1693 HE'S LOOKING FOR A PROPANE HEAD.
Flyin Farmall
10-25-2002 17:07:35
E-mail me with a $$$$ on the LP head please.
showcrop
10-29-2002 11:16:00
 Re: Re: Re: m piston height in reply to Flyin Farmall, 10-25-2002 17:07:35
Hey flyin' you aren't planning to pump up your motor like me are you? just dont go and put an electric fan on it and nobody will know.
farmallflogger
10-25-2002 14:25:00
Bob are you pulling that throttle wide open when you check your compression? It'll make a considerable difference. I had an M with about the same setup as your's and it had about 150 psi cranking compression. Truth be known unless your going real heavy or real fast 150 is enough. Pump gas is a whole lot cheaper too.
