Hitch for an F-20
Dave
10-29-2002 17:48:45
Any pointers on what to do on setting up an F-20 for pulling.What to do as far as the hitch would be my first concern.Probably depends what association you pull with? I love to watch 'em ,thought it might be fun to try.
Dave Houghton
10-30-2002 11:08:23
 Re: Hitch for an F-20 in reply to Dave, 10-29-2002 17:48:45
e-mail me what you have. tires, cubes, rpm,s etc. I,ll give you some idea,s. with the right set-up an f-20 can be very tough in the 4500 thru 5500 classes.
Dave
10-30-2002 16:35:40
 Re: Re: Hitch for an F-20 in reply to Dave Houghton, 10-30-2002 11:08:23
It's just a stock F-20,got 11.2x36 firestone tires.
Dave H
10-30-2002 16:52:19
 Re: Re: Re: Hitch for an F-20 in reply to Dave, 10-30-2002 16:35:40
This could be a problem unless you have the picker gear even with the slow tranny. If you could find a set of 24'', 26'', or 28'' rears it will help alot.I use the stock drawbar with a piece of steel flat welded on the bottom side for strength. I would suggest you have Motec go thru the carb. F-20 zenith carbs are under sized , Matt does a great job on these.
