Aluminum welding
Ohio H
11-02-2002 12:04:28
What is the best method for welding up aluminum weight brackets. Should I stick with mig,stick or is tig strong enough. I'm not sure about welding aluminum and you guy's know what works best. Thanks .....H
Andy
11-02-2002 20:22:36
 Re: Aluminum welding in reply to Ohio H, 11-02-2002 12:04:28
If your tractor is painted up nice I would spend a couple bucks and have someone tig weld them before you try it with an arc welder, TIG or MIG with a pulsator set right will look whole lot more profesional.
Brandon
11-02-2002 13:26:17
Tig would make a very good weld. You shouldn't have to worry about it breaking or cracking. Mig using aluminum wire and argon gas is also good. I'm not aware of any rods made to weld aluminum with a stick welder.
Brandon
Ohio H
11-02-2002 14:34:51
 Re: Re: Aluminum welding in reply to Brandon, 11-02-2002 13:26:17
Brandon; I'm told that aluminum rods can only be used with reverse polarity welders (ac/dc). Check welding suppliers or Lincoln electric, they gott'em. Thanks for the reply.....H
LW
11-02-2002 19:53:38
 Re: Re: Re: Aluminum welding in reply to Ohio H , 11-02-2002 14:34:51
DC neg reverse, they have them
Agent Orange
11-03-2002 17:02:10
 Re: Re: Re: Re: Aluminum welding in reply to LW, 11-02-2002 19:53:38
If you haven't used the Aluminum rods Either get someone that has to do it or go with the mig/tig. The rods are difficult to get used to! Also wear old clothes!
