8 inch JD Blocks?
bigmotors
11-05-2002 13:49:23
Anyone tried a 8 inch bore John Deere Block for a 80/820/830 yet?
How much with and with out pistons?
How much work to put one in?
Thanks
G Taylor
11-06-2002 20:23:30
 Re: 8 inch JD Blocks? in reply to bigmotors, 11-05-2002 13:49:23
How do they get the head gasket to seal with 15/16" of metal gone from around the bore? Is a stepped block/bore used similar to the gas power blocks? A stepped piston would be required as well to keep the compression up and provide an initial combustion chamber during injection?
REDDDOG
11-06-2002 12:32:36
call Max Turner with DATP he can get you in touch with carlyle enginering.
reddog
11-06-2002 12:36:45
 Re: Re: 8 inch JD Blocks? in reply to REDDDOG, 11-06-2002 12:32:36
sorry abot that hit Max s ph. 252-568-3604 or 252-559-0812
CASEPOWER
11-06-2002 08:44:20
You need to talk to Carlyle engineering he runs a ad in green mag. He pulls "Gang Green" around here and I believe it is 8". It is the meanest 2 cyl. puller I have ever seen.
Captainhookerus
11-05-2002 22:17:45
Hey bigmotors are you going to put two of them on your Chinese M ?
bigmotors
11-07-2002 06:31:20
 Re: Re: 8 inch JD Blocks? in reply to Captainhookerus, 11-05-2002 22:17:45
Sure! It will give people something to talk about.
It would be hard to find a head gasket for a 8 inch bore Massey. I know some people running this block in the southern areas, but nothing up the midwest way. I'd like to just hear one. THUMP/THUMP/THUMP!! You goda like it.
You going down to MO.?
Sounds like a small pull so far.
I'm not going, but who am I?
Good luck if you do!
