Super 51 Carb
BWB
11-05-2002 17:35:23
Is the Super 51 carbuerator rebuild that Robert's does worth the money? I have a G with stock stroke and milled head, and am trying to figure out whether to go for a standard rebuild or pay more and get the super 51. What are everybody's opinions? Thanks
BIG IRON
11-06-2002 16:37:21
 Re: Super 51 Carb in reply to BWB, 11-05-2002 17:35:23
Yes the super 51 will help your stock stroke engine. It added about 5 HP to my brothers G, he had some head porting done in addition to M&W pistons. I think all the talk about too much carb or manifold for a stock tractor is hog wash. Like the guy says an engine is just an air pump the more air you can get in the more power you will get out. I do think the post about saving your G carb and using an A carb for the mods is a good idea. I would also check around to see if you could find someone else to get a price from. You shoul be able to find someone to do it for less..."it ain't the space shuttle"
Gman
11-06-2002 16:20:18
BWB with stock bore and stroke I'd think long and hard about the super '51 it will support over 800+ ci it might be an overkill on 413 ci.Just my two penny's worth. Gman
Puller
11-06-2002 11:05:00
Before I would spend $400, I would look around at what some other places can do. There are other places that can rework your carburetor and get the same results for about half what Roberts charges.
G-MAN
11-06-2002 10:12:15
BWB, rather than modify your a stock 51, which are getting hard to find and expensive, I would suggest getting a gasoline "A" carb reworked. I talked to Robert about that, and he says he can modifiy a DLTX 71 to support up to 800 cubic inches. I believe he said it would be in the neighborhood of $400 for the whole job, including the rebuild. You might give him a call and get his opinion, as he is very helpful and knowledgeable. That's just an option and it's your decision, but I hate to see a good stock 51 get butchered.
