560 carb ?
rusty
11-06-2002 05:23:02
What can be done to a 560 IH carb to make it feed a little more. Are there different jets anyone has tried.
TURN IT UP
11-06-2002 15:49:27
 Re: 560 carb ? in reply to rusty, 11-06-2002 05:23:02
IS this a stock motor? Well if it is all you can do is drill out the high speed Jet to increase the fuel,just go two sizes up for now, also you need to get a bigger venturi,just one or two sizes bigger,then dyno the bit##,and see if it helped go a little at a time,so you can go back some,incase ya gone TOO far,play with ya timing also,again go slow,do one thing at a time and see what workes,don"t forget to check your valves gaps also,well got to run,my woman just came into my room with VERY LITTLE ON,I think she wants to play'''''''''''''''''''''''''''''''''''''#
farmallflogger
11-08-2002 06:12:27
 Re: Re: 560 carb ? in reply to TURN IT UP, 11-06-2002 15:49:27
Is she runnin a stock motor or does she turn it up a little?
