560d horsepower
farmall650
11-10-2002 04:56:14
ive talked to the fuel shop and he says he can get me between 90 and 100 hp by working on my pump how much more can i get if i add a turbo and how much boost will it stand thanks
IH
11-13-2002 18:50:18
 Re: 560d horsepower in reply to farmall650, 11-10-2002 04:56:14
Have 460 with d-282 with no sleeves=301,Decompressed pistons, lunati cam,a good head with oversize valves, to4b turbo at 2500 rpm makes around 200 HP..
John W
11-14-2002 05:42:14
 Re: Re: 560d horsepower in reply to IH, 11-13-2002 18:50:18
Can you pull sleeves out a 282 block and use 301 pistons in it? What about the the groove where the lip of the sleeve fits in on top of the block?
IH
11-14-2002 15:59:32
 Re: Re: Re: 560d horsepower in reply to John W, 11-14-2002 05:42:14
You must make a ring to go in the sleeve groove!!!!!
KEV
11-12-2002 18:06:34
Currently have 560 wheatland with T606 turbo on it and fuel turned up 25% and high idle no load 2600 rpm and it dynoed at 115 hp. to4b80 is good turbo to use for 1750 rpm.
cubic bucks
11-10-2002 06:14:13
Your 560's HP is directly porportional to how many bucks you spend. Get some aftermarket rods and pistons, billet crank and a girdle and 1500 should be possible. You'll probably need a Riverside head too.
cubic bucks
11-10-2002 06:10:10
660 Turbo
11-10-2002 11:26:17
 Re: Re: 560d horsepower in reply to cubic bucks, 11-10-2002 06:10:10
Farmall 650, do you know where to get these aftermarket rods, pistons, ect. We have a 660 with a turbo that has the fuel and rpms turned up. I think it is pushing about 120-130 hp. Haven't gotten a boost gauge for it yet though.
John W.
11-12-2002 15:57:29
 Re: Re: Re: 560d horsepower in reply to 660 Turbo, 11-10-2002 11:26:17
Could you tell me what brand and number of turbo that will work on a 282 diesel? Wanting to put one on mine one that will spin fast enough at around 1750 rpm. Any help appricated.
farmall650
11-10-2002 16:28:31
no iam just starting on mine now havent looked for parts yet
