Mile per hour pulling
baystatebinder
11-13-2002 05:47:24
New Brunswick just instituted a mile per hour rule. They have not determined the speed yet. I need some advice on how to pull this way. We have always used a dyno as the field leveling method. I need some advice please.
John
11-21-2002 14:12:56
 Re: mile per hour pulling in reply to baystatebinder, 11-13-2002 05:47:24
It depends on what it is your pulling. Are you pulling a stock or open classes. Where I'm from they run a speed limit in both. It's hard to say what to do. Some people like to run a gear high enough that they can go over the speed limit but keep the throttle down a little bit. Others like to run their tractors wide open in low gear and stay under the speed limit. You have to take in consideration track conditions and the overall setup of your tractor. If I have a hard packed track I like to run a gear that will go over the speed limit and keep the throttle pulled back a little. My tractor will bite into the track a little better that way. If I have a real bighty track I'll run a low gear with the motor mostly wide open. But their is no definite anwser to your question. Only you can decide! You know your tractor, do what you think wil work Trial/Error, and experience are the best ways to find out.
