HELP!
GEB
06-11-2001 06:58:17
This past Sat while pulling my D17 AC I had a bad problem. I misread the track and was too light on the front (my fault) but when my front end came up, my tractor cut off and when it went back down it caught up again but it was too late. There was plenty of fuel in the tank, but if that had been the problem there would have been enough in the line to run it for a few seconds at least. Any opinions or help would be appreciated (no bashing please). Thanx
Gary
06-11-2001 11:32:58
 Re: HELP! in reply to GEB, 06-11-2001 06:58:17
Check the bowl gasket in your carb. If it is leaking the fuel can get into the throat un-metered when you get it up in the air.
Jerry B
06-11-2001 08:41:33
Unless the fuel line is almost vertical when the tractor is on all four tires, the fuel will flow back toward the tank as the front end comes up.
