Rod length
Olman
11-15-2002 06:46:40
Are the connecting rods on an allis chalmers wd and wd45 the same length, or are the wd rods longer? Thanks for any help.
Mike B
11-15-2002 20:40:14
 Re: rod length in reply to Olman, 11-15-2002 06:46:40
Same lenght. Piston has different pin height.
Allis Puller
11-15-2002 21:08:08
 Re: Re: rod length in reply to Mike B, 11-15-2002 20:40:14
I think the only pin height difference is the 175 piston and I know for a fact its 1/4" taller than stock. The WD45's just had the power crator piston and from what I hear if you take a 45 crank and a WD flat top you'll get even more power.
Allis Puller
11-15-2002 12:38:28
I'm pretty sure they are the same, and the only difference is the 1/2" of stroke.
Orange Peel, WA.
11-16-2002 21:23:07
 Re: Re: rod length in reply to Allis Puller, 11-15-2002 12:38:28
I am thinking of going the WD-45 crank route with WD flat top pistons. Will this gain more pressure than using 175 pistons?
Allis Puller
11-16-2002 22:08:24
 Re: Re: Re: rod length in reply to Orange Peel, WA., 11-16-2002 21:23:07
Hello Tom, I recognized the email address, I tried several times to respond to your email but it kept coming back and it said it had fatal errors? So N-E-Ways if you have questions you can always reach me on this board. I honestly don't know about the flat top pistons and and a 4 1/2 crank, I've only heard it makes a lot of compression. My 175 pistons make 185 lbs of compression which is plenty, just don't buy after market 175's, they are'nt any different exept they are 1/8" wider. The true 175's were 1/4" taller and thats what makes the h.p. You could get the 175's and have them filled in with weld to make them flat top and they'd probably be really tough. The 175's will run you around $600.00 - pretty pricey but well worth the h.p. Kurt
