99 crank
oliver puller
11-16-2002 15:19:12
Im building oliver 88 I want to use a 99crank what can I expect to pay
195 puller
11-16-2002 16:43:57
 Re: 99 crank in reply to oliver puller, 11-16-2002 15:19:12
I have one crank left that is out of a 195gk motor. It is ground 10 under. It is the same as a 99 crank. I also have a set of rods. If you want to build either a high rpm engine or just an engine that you want to have a very strong bottom end then I would recomment these rods, they are pressure lubed and have a 4-5/8 journal. They have just as much clearance in the block as an 88 rod would have. I am asking $800 for the crank and the rods and would throw in a set of 4-1/8 inch aluminum pistons. I also have gear oil pumps and pans to fit if they are needed.
oliver puller
11-24-2002 10:06:23
 Re: Re: 99 crank in reply to 195 puller, 11-16-2002 16:43:57
195 puller please E-mail me with more info on your 195 parts
oliver puller
11-24-2002 16:13:48
 Re: Re: Re: 99 crank in reply to oliver puller, 11-24-2002 10:06:23
195 puller myE-mail addres is olsu88@hotmail.com
ted
11-16-2002 15:28:27
Any where from $500 to $1000- They are getting kinda hard to come by.
oliver puller
11-16-2002 15:35:15
 Re: Re: 99 crank in reply to ted, 11-16-2002 15:28:27
will A 195 crank work as well as A99 crank if so how much would I expect to pay
ted
11-17-2002 05:51:37
 Re: Re: Re: 99 crank in reply to oliver puller, 11-16-2002 15:35:15
A 99 engine is a 195.
