Distributor Advance Curve
Ted
11-20-2002 19:36:54
Can someone enlighten me as to how much total timing is realistic for a 2000 rpm 6cyl.I know there are a number of factors to take into consideration but as a general rule what would be ballpark.I find it hard to believe that when you send a distributor to be dialed in that you get it back with a calibration "specifically" curved for your setup.If your initial timing is 20 degrees plus the advance gives another 25-30 isn't that going to light it up a bit to early?
burns
11-21-2002 10:27:14
 Re: Distributor Advance Curve in reply to Ted, 11-20-2002 19:36:54
I'm not sure that "specifically" is the correct way to look at it but more "proportionally". For example, Deere would set their distributors at full advance @600rpms. If you are running 10% or 1100-1200rpms, you can have peak advance set for the highest rpm range and have your mid-range calibrated to retard with rpm. It is as simple as a few weights and springs to achieve the desired range.
I'd call Matt at Motec for more specific info.
