730 puller
John
11-21-2002 13:33:34
Our family is kind of new to John Deere, we've always ran the other color green. Anyhow we ran into a 730 gas that we couldn't pass up. We we're wondering how many cubes and how many horses we could get. We want to go as big as possible! Can they be built to compete with power block JD G's?
Any help would be much appreciated!
Duben
11-21-2002 16:56:32
 Re: 730 puller in reply to John, 11-21-2002 13:33:34
I have both a G and a 730D. Low gear on the G is about 2 1/2 mph while it's about 1 1/2 on the 730. You need lots of power because of the high speed gearing on the G, however, the 730 will always run out of tracton before power in low gear with no modifications. You should be able to get into a much lower weight class with the gas tractor that I can with a diesel. You can have fun and not run out of power just the way it is. Good luck.
WILDCHILD
11-22-2002 15:08:34
 Re: Re: 730 puller in reply to Duben, 11-21-2002 16:56:32
You will be happer with the other color green,That is if you like to win.Otherwise 730's are ok.
