Farmall M Stroker
Antique puller
11-21-2002 20:38:47
might build a stroker motor for a Super M
and had a few questions .... all advice or help greatly appreciated. Hoping to get 85 to 100 HP
don't have a clue how far to go on the stroke.
How far can a Farmall M or Super M crank
be stroked before grinding of the block is required?
what is involved with grinding the block?
What pistons can be used for a 4.125" bore with
what stroke?
Can email me if you prefer. thanks
puller
11-23-2002 18:59:41
 Re: Farmall M Stroker in reply to Antique puller, 11-21-2002 20:38:47
for pistons use 4010 LP piston,
JJ
11-22-2002 17:36:02
I have a stroker motor for sale complete.937-393 8316
OhioMPuller
11-22-2002 10:09:21
Did you get my email? If so did you do the search on FREE ADVISE at the top of the Forum.
Ohio M Puller
Deal With It Pulling
Adam
11-22-2002 08:31:44
Just a comment but if it was me and I was going to stroke a motor I would but bigger piston's in it than just 4.125. I would go with a 4.5. Might as well if your going to spend all that money on stroking the motor any way. Just a suggestion.
Antique Puller
11-22-2002 09:23:03
 Re: Re: Farmall M Stroker in reply to Adam, 11-22-2002 08:31:44
What would have to be done to go that far on
the bore. Will I still have sleeves or run in the
block?
Hank
11-22-2002 09:40:20
 Re: Re: Re: Farmall M Stroker in reply to Antique Puller, 11-22-2002 09:23:03
If your looking for 80 to 100 horse just go with a 4.375 bore by 6.00 to 6.50 stroke either should get you there.With that bore size you shouldnt have any problem with head gasket sealing.just my 2 cents better safe than sorry and you can bore that in the block and not use sleeves.
Antique Puller
11-22-2002 09:51:38
 Re: Re: Re: Re: Farmall M Stroker in reply to Hank, 11-22-2002 09:40:20
Is there a ring at the top of the block after the sleeves are removed? What is done about that?
