Farmall 400 head
T.L
11-23-2002 14:57:28
what can be done to a gas farmall 400 head to make more power. right now it is 281 cubes and 160 psi compression. I am trying to get more power out of my tractor. any advice would be appriciated.
Farmall Daddy
11-26-2002 12:08:18
 Re: farmall 400 head in reply to T.L, 11-23-2002 14:57:28
My dad and I have a Farmall M and we put a 450 head on it for more power and it is supposed to bump the power 10 horsepower. It may not be what you are looking for but I would try this.
jcm
11-24-2002 05:41:49
Don't know what you got done already but you can get it milled,bigger valves ,port/polish job.Have you made any changes in the camshaft?But what ever you do try to do it in steps to tell what helped and how much.
T.L
11-24-2002 07:25:50
 Re: Re: farmall 400 head in reply to jcm, 11-24-2002 05:41:49
how much horse power will i gain by porting and polishing the head. and by milling it. will i half to grind the intake manifold to match the head.
jcm
11-25-2002 15:00:06
 Re: Re: Re: farmall 400 head in reply to T.L, 11-24-2002 07:25:50
Depending on your piston (flat or dome) I would try getting the head shaved first.If you have a trustworhty engine machine shop ask them on how much.You may want to go only .050 or up to .120. as far as hp goes everyones different.You may not even see it on the dyno but you can tell on the track.Also if you go this route be mindful of your timing.
