Need help finding a head gasket for a farmall 460?
Jason B.
11-25-2002 16:58:56
i have a 1960 farmall 460 diesel with a wide front. i am looking for a new head gasket posobly a copper one if i can get one? I am sending the head in to get new valve seats in it. i have all new injectors and a new head on the injector pump. it runs great but the valves need work and i was wondering if theres anything i should do else. i am planning to pull with it in the spring. any tips of info will be much appreciated thanx.
Jason B.
11-26-2002 19:13:48
 Re: need help finding a head gasket for a farmall 460? in reply to Jason B., 11-25-2002 16:58:56
i needed new injectors because the guy i bought it from mixed the new and old style injectors and it made the tractor run bad. so i got all new one's and had the pump boosted up so it pumps more fuel. now it runs better (ALOT!) but the valves still need work. Any way's i was wondering if there is any specific problems i shold know about in this tractor. ive herd about piston skirt problems? i am not planning on doing any lower engine work just topend. Also does any one here pull with a diesel 460 wide front end i just want to know how it might do. well thanx for any comments.
redhead
11-27-2002 18:14:38
 Re: Re: need help finding a head gasket for a farmall 460? in reply to Jason B., 11-26-2002 19:13:48
Make sure the tranny and rearend is up to snuff. They had alot of problems at the start of production (nothing more than a H setup with different gear ratios). Bearing failure in the bull gear drive and axle areas was common. Also, the TA has to be tight too. Good Luck.
redhead
11-25-2002 18:49:21
Cooper head gaskets are great when their needed (HIGH compression ratios and/or BIG bores). If this isn't the case, stick with stock head gaskets, they are much less fussy. If you have to have copper, call Gasket Works USA at 626-358-1616, they will fix you up. Good Luck.
Brad
11-26-2002 12:20:58
 Re: Re: need help finding a head gasket for a farmall 460? in reply to redhead, 11-25-2002 18:49:21
I agree. We hold over 14:1 compression on a 560 with a stock gasket. The head and block are both grooved so that a piece of stainless wire makes a mechanical seal.
baystatebinder
11-30-2002 10:01:23
 Re: Re: Re: need help finding a head gasket for a farmall 460? in reply to Brad, 11-26-2002 12:20:58
put a 560 crank in it and you will have a strong pulling tractor
