Holset charger
BigRedMachine
11-25-2002 23:18:29
Does Holset make a turbo that is the same size/dimensions as a 3lm 466 turbo?
Scott Williams
11-26-2002 05:23:24
 Re: holset charger in reply to BigRedMachine, 11-25-2002 23:18:29
The Holset H-2 is close. It may be just a slight step above the 3lm schwitzer. What are you planning on doing with it? The exhaust housing should have the same mounting dimensions as the 3lm, but the compressor side might require some modifications if you are trying to replace a 3lm with the H-2.
