About my 460 diesel manifold
Jason B.
12-03-2002 13:23:24
should i port my manifolds so the engine can breath a little better. and also i herd some guy say that i should use some kind of special valve?
any help will be greatly appreciated and thanx for the past info.
TimC
12-04-2002 18:55:35
 Re: about my 460 diesel manifold in reply to Jason B., 12-03-2002 13:23:24
More air means more oxygen and you can burn more fuel. Better flowing is always better if the velocity of the charge is the same or better. If you get to large of a cross section in the manifold then volume and pressure increases but velocity decreases causing less power. At low RPMs, long and small gets the most torque. You can back cut the valves and get a three angle valve job which should increase max cfm yet still maintain velocity. Your next step would be to add more fuel. Bowl blending might help.
Gatz
12-11-2002 15:29:26
 Re: Re: about my 460 diesel manifold in reply to TimC, 12-04-2002 18:55:35
What do you mean by bowl blending? are you talking about dishing the pistons? if so won't you lose comp?
TimC
12-12-2002 19:54:32
 Re: Re: Re: about my 460 diesel manifold in reply to Gatz, 12-11-2002 15:29:26
Where the runner merges into the pocket, (the area above the valve). Clean up any rough edges and create a smother transition without increasing the cross sectional area too much.
Grizzley Bear
12-03-2002 20:20:39
I can get you a setup like mine...a IH V-8 truck heads put together with the wrong length block and totally homemade manifolds!! It works great!! Of course, you'll have to pay off any of your local club board members for them to approve of it! If they are as easy as the ones I just bought off, it's worth it! Let me know!
Baby Bear
12-04-2002 18:05:41
 Re: Re: about my 460 diesel manifold in reply to Grizzley Bear, 12-03-2002 20:20:39
I was wondering where I could get the number for a machine shop that would build something that shady, Grizz can you hook me up? Also, must be absolutely identical to Papa Bears and be able to withstand "PRESSURE".
Papa Bear (Colorado)
12-04-2002 22:46:08
 Re: Re: Re: about my 460 diesel manifold in reply to Baby Bear, 12-04-2002 18:05:41
Call Lemon's in Indiana, they just build it, don't care if it meets rules or not! They will build ANYTHING!! Even have the Div 4 guys thinking those "recast" 450 lp heads are legal!! They will give you whatever you want, yes it's shady/illegal, although you may feel a little UNDER PRESSURE! Remember to pay off the board members and it is a for sure legal thing then!
1HOT560
12-05-2002 14:38:22
 Re: Re: Re: Re: about my 460 diesel manifold in reply to Papa Bear (Colorado), 12-04-2002 22:46:08
My 2 cents..... let the bear thing go... what does that have to do with the question anyway? .. apparently you guys havehave been beat and got a chapped a$$ about it..you prob. dont even run div.5 and if you do deal with it and spend some money to compete....dont blame lemmons they just build what the customer wants.... They do quality work and I have always been satisified..... ..
