Carb for a U
Family Traditio
12-04-2002 16:43:49
what is the best carb for a U w/4.75 bore and 6 inch stroke ported and polished 4207 heads and y intake..... running about 300 lbs of compression per cylinder..... ...currently running a carb off of a 4010 gas JD
U-puller
12-04-2002 17:46:16
 Re: carb for a U in reply to Family Tradition, 12-04-2002 16:43:49
I have a utu that is built with 1/4 inch. more stroke than yours is and I am running the stock carburetor. There are many things that you need to do to the carb. to get it to work, but it works excellent when it is done. Call Matt at Motec and he will tell you the specifics. I would be on here all night if I tried to explain how to do it.
Slo
12-04-2002 17:24:29
Call Matt at Motec. 765 963 6628
