900 2nd gear
Rob Mo.
06-17-2001 18:11:11
This past Friday, I took my Ford 900 to a tractor pull. I pull in 2nd gear & I was wandering what the gear ratio is. Is there another Ford trator tha has the same 2nd gear ratio. Maybe a Jubilee. Could I change transmissions from a Jubliee & put it in the 900.
Hey Rob....Burns
06-19-2001 18:55:37
 Re: 900 2nd gear in reply to Rob Mo., 06-17-2001 18:11:11
I just got off of the phone with the owner of the 900. Carl is running 15.5x38 6 ply tires. When he added the 15.5's, he had to remove the 3 point arms and his weight brackets to be able to get into the 3500# class. He runs the tractor at 2400rpms. He doesn't pull 2nd because of the condition of his clutch. First gear is around 3.4 mph and 2nd is around 5 mph. This is the info he gave me so don't shoot the messenger.
Oh, I asked about the color of his tractor. According to him, from 55-57 the 900's had gray tin with a red body. This was similar with the 901's. When the 4000 series came out, the tractor was painted blue. I was just curious, so don't think I am critizing your tractor. :^)
missery
06-19-2001 15:08:31
i have pulled this tractor befor. if this had a tire option of 38's on the rear,go to your pick up and get it. i want to see it. i pulled our 900 in the 3500,4500,and yes in the 5500 ls class. in the 3500 class i was in 3rd gear. does pretty good.the other two classes , it was in 2nd. it has the 5 speed trans in it.hated to see that guy on the farmall m cry like that:)this was done with 13.6/28'sgreat little tractor to pull...
Rob Mo.
06-19-2001 21:44:10
 Re: Re: 900 2nd gear in reply to missery, 06-19-2001 15:08:31
How much wieght did you hang on that tractor. Our tractor weighs around 4050lb. right now. I have a hard time making it 4500lbs. I assume you hang suitcase weights on it, but where. The front or back.
missery
06-20-2001 16:06:16
 Re: Re: Re: 900 2nd gear in reply to Rob Mo., 06-19-2001 21:44:10
i had 11 one hundred lb weights on the back. i also had the stock pie weights that goes in the wheels too. that put me around 5500lb. by the way, i took fourth place that day out of 22 tractors. dave
Rob Mo.
06-21-2001 08:53:08
 Re: Re: Re: Re: 900 2nd gear in reply to missery, 06-20-2001 16:06:16
I am well awhere of what this tractor can do. It can pull damn good. I recently went out & bought a 2"x1"x28" piece of steel. I was going to make a drawbar for it. I figure I would pull it up to 20" & make it closer to the tractor. Thsoe pie weights, are they hard to find. I would like a pair. we always just borough some from a friend. hat do they go for now?
missery
06-22-2001 04:02:52
 Re: Re: Re: Re: Re: 900 2nd gear in reply to Rob Mo., 06-21-2001 08:53:08
we are paying around 300.00 a set.the set weight is about 1100 lb. i pulled againced a 900 with 38's last year in N.H. that thing was a rocket. dave.
david futrell
03-11-2005 15:00:55
 Re: Re: Re: Re: Re: Re: 900 2nd gear in reply to missery, 06-22-2001 04:02:52
were do u get those pie weights for the ford 900 i am in very desperate need of a set u say 300.00 i need them now yesterday
burns
06-18-2001 10:40:34
Rob does your tractor look similar to this one (first photo)? I know the owner of this tractor claims that second is too big of a jump. His dynos around 45-46hp. It is a tough little tractor in the lighter classes unless the track is taking power then he has a hard time balancing the ol' girl.
pete
06-18-2001 19:05:20
 Re: Re: 900 2nd gear in reply to burns, 06-18-2001 10:40:34
rob-do NOT take advice from a G puller who only knows what it feels like to run "1st gear"...whoooaaaaa a hang on!!!!! !!
burns
06-18-2001 20:26:41
 Re: Re: Re: 900 2nd gear in reply to pete, 06-18-2001 19:05:20
I was enjoying reading a variety of post that didn't have an a$$hole adding his two cents. You mentioned that we would be pulling against each other at some point this summer. You need to send me an email so that I make a point to go. Oh I forgot, you don't have an email or balls to find one.
I think Rob can make his own judgement as to who he is going to take advice from, besides I don't remember offering any advice.
Rob Mo.
06-18-2001 13:39:11
Ya, it is very similiar. Except, for ours has power adjust wheel & is painted blue instead of where the red is. Ya' It is a good tractor in the 4000lb. weight class, but I can't do anything in the 4500lb. class. What class does he pull in with his. What type of tires, how high is the drawbar, & how much weight does he hang on it?
burns
06-18-2001 20:30:38
 Re: Re: Re: 900 2nd gear in reply to Rob Mo., 06-18-2001 13:39:11
Rob I'll have to get back to you on the particulars of his tractor. I do know the rears are 38's but not sure on the width. I'll send him an email on your questions.
Rob Mo.
06-18-2001 20:42:08
 Re: Re: Re: Re: 900 2nd gear in reply to burns, 06-18-2001 20:30:38
There anin't 38's on a 900, there are 28's. I appreciate the help. I take it you & "Pete" compete with one another.
burns
06-19-2001 05:42:12
 Re: Re: Re: Re: Re: 900 2nd gear in reply to Rob Mo., 06-18-2001 20:42:08
Carl, the owner, was telling me that he gets a lot flack because he is running the larger thirty eight inch diameter tires. I don't care either way, but he mentioned that they were a factory option. However, I do like to pull his chain about his non-stock tires :')
Pete has a way with words that makes everyone feel warm and fuzzy inside ROFL.
pete
06-19-2001 09:55:28
 Re: Re: Re: Re: Re: Re: 900 2nd gear in reply to burns, 06-19-2001 05:42:12
Rob, i wouldn't say burns really "competes", he just "attends and participates" at the pulls!!
Eric
06-19-2001 05:12:11
Rob, i know for a fact that there are two ford 900's here in southern indiana that are running 38" tires. 13.6-38 i believe. they seem to do real well in the 4000 and 4500 lb uncut tire classes.
Rob Mo.
06-19-2001 09:44:01
 Re: Re: Re: Re: Re: Re: 900 2nd gear in reply to Eric, 06-19-2001 05:12:11
I want to see a picture of these Ford 900 on 38's.
My mailing address
Robbie Pisane
848 Porterford Rd.
Union, Mo. 63084
Eric
06-20-2001 04:27:23
 Re: Re: Re: Re: Re: Re: Re: 900 2nd gear in reply to Rob Mo., 06-19-2001 09:44:01
Rob, three pics of fords with 38" tires are in your hotmail email. if you still dont believe it i will get some better pics where you can read the letters on the tires. i would have just posted them here. but i dont understand how to do that.
Eric
Eric
06-20-2001 04:27:11
Eric
