Anyone know how far a John Deere B Powerblock can be BORED?
2 cylinder
12-05-2002 20:56:02
I want maximum cubic inches, how far can it be bored? And how far can you bore a re-sleeved cylinder in a powerblock? THANKS!
bigmotors
12-06-2002 17:30:05
 Re: Anyone know how far a John Deere B Powerblock can be BORED? in reply to 2 cylinder, 12-05-2002 20:56:02
Alot go 5.125 to 5.1875 I would think 5.250 would work. Sleeved to 5.500/ Hard block 5.750
I ran a 1944 reg. block 4.500 bore, at 5.500 bore for years.
It leaked really bad!! But, it worked.
Good Luck!
2 cylinder
12-07-2002 18:59:14
 Re: Re: Anyone know how far a John Deere B Powerblock can be BORED? in reply to bigmotors, 12-06-2002 17:30:05
Thanks for you information! Are there any other ideas? Thanks!
bigmotors
12-08-2002 13:39:39
 Re: Re: Re: Anyone know how far a John Deere B Powerblock can be BORED? in reply to 2 cylinder, 12-07-2002 18:59:14
Not to be a smart-ass, I would spend my money on a A before a big B. Same money, more options. It is thou, alot of fun beating bigger tractors with a small one. What year B are you going to use? The B is the hardest one to put a crank in. No room to get in there-to make room for the crank. 7 to 7 1/2 makes a good set up. I know of a B that has a 8 3/8 crank! It took alot of beer to put that one in.
Good Luck!
2 cylinder
12-09-2002 13:30:17
 Re: Re: Re: Re: Anyone know how far a John Deere B Powerblock can be BORED? in reply to bigmotors, 12-08-2002 13:39:39
The reason for building the 42 John Deere-B is so I can pull the lighter classes 3500-4500. I do have a 47 JD-A with a powerblock in it , it is not stroked with 6.125 bore with dyno's 55hp which I pull in 4500-5500, and also pull a 68hp 51 JD-G nonstroked that I pull in 5500-7000 classes. I just purchased a powerblock for the B a would like to do the crank while I have it apart. My brother has a B with 4 5/8" bore and 7" stroke that is alot of fun to pull so I wanted to build my own a go with the powerblock and as much stroke as I can without relocating the camshaft. If you have any good suggestions I would be happy to here them
Drew
12-09-2002 14:03:11
 Re: Re: Re: Re: Re: Anyone know how far a John Deere B Powerblock can be BORED? in reply to 2 cylinder, 12-09-2002 13:30:17
You can make 3500 with an "A" Its not easy nor cheap, but it can be done. On the B, you will want a Heisler head/manifold and a bored out "A" carburator to feed the beast. You said 3500-4500 lbs, do they have a 3250 in your area? The B can be gutted to make 3250 with a little work. Good luck on the "B"!
a puller
12-11-2002 06:38:19
 Re: Re: Re: Re: Re: Re: Anyone know how far a John Deere B Powerblock can be BORED? in reply to Drew, 12-09-2002 14:03:11
where can you get a heisler head for a b, or any tractor? thanks,
John
