BEST CYLINDER HEAD TO USE FOR A 42 JD-B WITH A POWERBLOCK?
2 cylinder
12-07-2002 19:18:24
What cylinder head should I use and what modifications should be done to the head, intake and valve train? I am building a 42 JD-B with a powerblock with a stroker crank. Any imput would be welcome.
Wendel
12-10-2002 09:02:34
 Re: BEST CYLINDER HEAD TO USE FOR A 42 JD-B WITH A POWERBLOCK? in reply to 2 cylinder, 12-07-2002 19:18:24
I HAVE A 41 B WITH LATER MODEL P/BLOCK GOING TO RUN A 7" STROKE I AM CONSIDERING USING 50 LP HEAD,50 CARB. AND MANIFOLD.SO FAR THIS JUST BENCH PULLING WIL BE A FEW BUGS TO WORK OUT BUT HAVE BEEN TOLD THIS WILL WORK.
WTW
12-10-2002 10:55:20
 Re: Re: BEST CYLINDER HEAD TO USE FOR A 42 JD-B WITH A POWERBLOCK? in reply to Wendel, 12-10-2002 09:02:34
Wendel, I hope the later Power-block that you are planning on using is the 50 Power-block as the head will fit it and not the a "B" power-block. The 50 block has one more head bolt stud and a different bolt pattern than the "B". The 50 block pattern to the case is also different but would be allot easier to alter than the head end of block. Good Luck, D.W.
